Ubuntu 20.04 freezes and message on remote console is as attached.
Did ILOM hard reset to reboot.
Anyone know how to identify the process that caused the oom and why would Ubuntu freeze?
The process, that triggered the OOM, is node. As you can see behind the process id 1908036. I is hard to guess, what is going on in you system, but from the cgroup out of memory I assume, that there are some containers running node-js.
Start by increasing the swap space of your system and monitor memory consumption while it is running. If the memory consumption is high than your physical available memory, you should consider using a system with more memory.
