10
I have upgraded my Ubuntu 16.04 to 20.04 and have installed Xfce which I'd like to set as the default DE when logging into my system. However, everytime I login with Xfce and logout, Ubuntu forgets Xfce as the default DE and goes back to the option Ubuntu (Unity).
Following How do I set the default desktop environment on 18.04 (Bionic)?
I tried
sudo update-alternatives --config x-session-manager
in the terminal. However, what I get is
There are 3 choices for the alternative x-session-manager (providing /usr/bin/x-session-manager).
Selection Path Priority Status
0 /usr/bin/gnome-session 50 auto mode 1 /usr/bin/gnome-session 50 manual mode 2 /usr/bin/startxfce4 50 manual mode
  • 3 /usr/bin/xfce4-session 40 manual mode
Press <enter> to keep the current choice[*], or type selection number:
which apparently indicates that Xfce should be the default DE which is not the case. Any help would be appreciated.
Simon
  • 201
When I upgraded to Ubuntu 22.04 LTS from the previous LTS I also had the issue where the default desktop stopped being Xfce. In my case, my /var/lib/AccountsService/users/<my-user-name> contained a Session property as well as the XSession property. The Session property was empty.
[User]
Session=
XSession=xfce
Setting Session=xfce made Xfce the default desktop environment for me again.
check cat /var/lib/AccountsService/users/your-username. Make sure that XSession is set to xfce.
s3idani
  • 423
