12
I've installed Gnome Flashback and can select it on the log in screen: enter image description here
Unfortunately, every time I restart I'm automatically logged into the original "Ubuntu" (Gnome 3) environment again. The solutions in these related questions don't work anymore:
how to set default session in Ubuntu 14.04 LTS?
How do I change the default session for when using auto-logins?
Specifically, setting user-session to gnome-flashback-metacity in /usr/share/lightdm/lightdm.conf.d/50-ubuntu.conf has no effect.
How do I fix this?
5 Answers5
$ sudo update-alternatives --config x-session-manager
(you can also add other DM via
sudo update-alternatives --install /usr/bin/x-session-manager x-session-manager /usr/bin/gnome-session-classic 60
[assuming the new session manager is /usr/bin/gnome-session-classic :-]
You can change the default Desktop environment file in user Account file.
cd /var/lib/AccountsService/users
Select the specific user file
Here change the "xsession" value to "GNOME Flahsback (Metacity)"
h-neo
  • 61
You could reconfigure your default display manager using these steps in the terminal. I am assuming that your default is gdm3 and you want to move to lightdm
$ sudo dpkg-reconfigure gdm3
<OK>
lightdm
MoJo
  • 41
Found a workaround. Install LightDM (which IMHO looks much better than the default GDM):
sudo apt-get install lightdm
Then disable and re-enable autologin (if needed). This creates a working configuration that remembers your selected desktop environment.
Run sudo dpkg-reconfigure gdm and select the default display manager in the dialog that pops up. You can replace “gdm” with any of the display managers that are currently installed on your system. If this fails, you can edit the /etc/X11/default-display/manager file with root privileges https://www.makeuseof.com/tag/choose-switch-linux-display-managers/
