The problem is that it suddenly hangs once the service gdm.service starts. I know this because I have set it to display the processes instead of the splash screen and the last thing that comes on the screen is gdm.service, after which the computer hangs.
I do not think the problem is with the graphic drivers. Adding nomodeset to GRUB does not help.
If I go into recovery mode and drop to root shell, it automatically hangs after a few seconds.
Also, for some reason I cannot mount /boot/efi on /dev/sda5.
I have set up dual-boot configuration with Ubuntu and Windows 10.
I get this problem every time I shut down my computer and start it again. Every time I just unplug the things and restart it works but in this situation, it doesn't.
If I use an older version of Ubuntu, I get everything started but the problem is that there is no Bluetooth or networking even though it is connected via Ethernet.
Also the original problem started because I started WiFi and had to restart my computer.
I cannot even ssh into my computer.
If somehow I can get to a tty it hangs there too. I can ssh before it hangs, but as soon as the computer hangs, I cannot execute any commands.
Could someone give me a temporary solution to this? I don't plan on ever shutting it down again. All my research is on the hard drive which is not backed up.
