I recently (~2 weeks) switched to Ubuntu and the sound is crazy distorted at volumes higher than 50%. At 50%, the speaker volume is not high enough for regular usage. I've so far tried tweaking around with AlsaMixer and replacing PulseAudio with Pipewire and neither solved my problem.
How do i fix this?
To see a sample of the distortion, here's a 45 second video. You can skip ahead to 35 (-10) seconds / 15 (-30) seconds to hear the distortion.
Note - this isn't an issue with the speakers/hardware as they worked perfectly fine when I used Windows.
I own an Acer Swift 3 (2018 version) - SF314-52. Terminal Output of sudo lspci -v:
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21) (prog-if 80)
Subsystem: Acer Incorporated [ALI] Sunrise Point-LP HD Audio
Flags: bus master, fast devsel, latency 32, IRQ 129
Memory at b1120000 (64-bit, non-prefetchable) [size=16K]
Memory at b1100000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [50] Power Management version 3
Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel, snd_soc_skl
Updating: adding output of aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC255 Analog [ALC255 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
