I recently installed Ubuntu 20.04.
I attempted to install apps from the Ubuntu software center, but it isn't working correctly.
  1. No icons are displayed. https://ibb.co/Rc4BmF0
  2. No screenshots or information about the applications are displayed. https://ibb.co/GRWCmQm
I tried Ubuntu Software not loading properly but it didn't work.
How to fix?
[ 7740.813470] audit: type=1400 audit(1641719624.368:91): apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap.blender.blender" pid=12796 comm="apparmor_parser"
[ 7740.813479] audit: type=1400 audit(1641719624.368:92): apparmor="STATUS" operation="profile_load" profile="unconfined" name="snap-update-ns.blender" pid=12795 comm="apparmor_parser"
[ 8529.948443] perf: interrupt took too long (5343 > 5252), lowering kernel.perf_event_max_sample_rate to 37250
[ 9331.941196] audit: type=1326 audit(1641721215.520:93): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.snap-store.ubuntu-software pid=14223 comm="snap-store" exe="/snap/snap-store/558/usr/bin/snap-store" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7fb1dcf0489d code=0x50000
[ 9538.128342] audit: type=1326 audit(1641721421.710:94): auid=1000 uid=1000 gid=1000 ses=3 subj=snap.snap-store.ubuntu-software pid=14475 comm="snap-store" exe="/snap/snap-store/558/usr/bin/snap-store" sig=0 arch=c000003e syscall=314 compat=0 ip=0x7fdcec47389d code=0x50000
Hannu
  • 6,605
  • 28
  • 45
This issue has existed for a long time. Ubuntu's Snap store isn't well-maintained and doesn't perform properly. As a result, in Jammy 22.04, they've chosen to use Gnome software instead. Gnome software is working fine without any issues. You can install gnome-software using:
$ sudo apt install gnome-software
If you want to remove the Ubuntu software app:
$ sudo snap remove snap-store
Gnome software is way better than the default application centre. The user interface is nearly the same.
Note: Ubuntu Snap Store is a re-designed version of Gnome-Software but unfortunately with bugs.
You can launch gnome software using:
 $ gnome-software
You can also launch it using the application overview.
Here is how it looks like:
Gnome software Icon
Here is the UI of Gnome Software in Ubuntu 21.10:
Gnome Software UI
You can install additional plugins for it too. For example, you can run the following command to enable the snap plugin in Gnome Software:
$ sudo apt install gnome-software-plugin-snap
If you want to enable flatpak support then you can run:
$ sudo apt install gnome-software-plugin-flatpak
Error404
  • 8,278
  • 35
  • 60
