i have an issue with nvidia drivers causing steam games to freeze or crash.
more is explained in this question, where i have been told that if the errors from sudo ubuntu-drivers autoinstall were fixed, steam would also work.
the output of the command is:
Reading package lists... Done
Building dependency tree
linux-modules-nvidia-495-generic-hwe-20.04 : Depends: linux-modules-nvidia-495-5.11.0-43-generic (= 5.11.0-43.47~20.04.2) but it is not going to be installed
Depends: nvidia-kernel-common-495 (>= 495.44) but 495.29.05-0ubuntu1 is to be installed
I am using 470 proprietary drivers on my nvidia 1660ti on kubuntu 20.04 LTS
sudo apt --fix-broken install [18:58:54]
[sudo] password for lovro:
The following packages were automatically installed and are no longer required:
libavresample4 libgl1-mesa-glx:i386 python-is-python2 python3-pyudev
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
thanks in advance
