I have Ubuntu Server 20.04 installed on an early 2011 MacBook Pro 8,1 and I want to close the lid and turn the screen off. I have succesfully prevented it from sleeping when closing the lid as described here https://askubuntu.com/a/594417 and from another answer https://askubuntu.com/a/1117586 in the same question, I created a script to trigger the screen on/off. This script gets executed I have confirmed that with logging the calls to it.
The first problem is (was) that
sudo vbetool dpms off
resulted in this
mmap /dev/zero: Operation not permitted
Failed to initialise LRMI (Linux Real-Mode Interface).
So I tried the solution here Ubuntu 20.04 on a laptop - is there any way toturn off the screen? that adds this
sudo mount -o remount,exec /dev
sudo mount -o remount,noexec /dev
but it results in
Real mode call failed
and yes the screen does not turn off
I tried xset and xrandr but they can't open the display
The installation is headless without GUI
uname -a
Linux oldlaptop 5.4.0-91-generic #102-Ubuntu SMP Fri Nov 5 16:31:28 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
cat /proc/cmdline BOOT_IMAGE=/vmlinuz-5.4.0-91-generic root=/dev/mapper/ubuntu--vg-ubuntu--lv ro
Any ideas how to turn off the screen, either using vbetool or any other?
bits
  • 133
I ran into the same exact wall.
The only solution I found is turning off the screen after a period of inactivity. (This completely removes the need for acpid and lid.sh)
There are two options. The first is to use the following command:
setterm --powerdown 1
Note: If you are testing this out, it doesn't work over SSH. So to test it, you need to run it from the laptop directly. You can put that in a script and have it run at boot.
Second option, and what I did: Add consoleblank=60 to the GRUB commandline:
sudo nano /etc/default/grub
Edit line to read:
GRUB_CMDLINE_LINUX_DEFAULT="quiet consoleblank=60"
Reboot.
Smolakian
  • 101
