I installed Ubuntu server 20.04 on old, damaged laptop. The problem is, that I can not close the cover - this is the "damaged" part of the problem.
Is there any way to turn off the screen via command line?
I found such solution: sudo vbetool dpms off, but it does not work and returns error:
mmap /dev/zero: Operation not permitted
Failed to initialise LRMI (Linux Real-Mode Interface)
How can I turn off the screen? Is it even possible with command line only?
Zorann
  • 133
I had the same issue on Ubuntu 20.04 LTS server.
$ sudo vbetool dpms off
mmap /dev/zero: Operation not permitted Failed to initialise LRMI (Linux Real-Mode Interface)
Finally I found the solution here.
You have to use 2 extra command.
In order:
sudo mount -o remount,exec /dev
sudo mount -o remount,noexec /dev
To turn on again the display:
sudo vbetool dpms on
Belushi
  • 486
