I have installed Ubuntu 20.04 on a new PC and using wifi dongle (https://www.amazon.in/Live-Tech-Nano-Wirless-Adapter/dp/B078SSXTG7) to connect to wifi. I have saved the passwords, but every time on starting Ubuntu, I have to manually connect to the wifi network and provide password. It does not automatically connect. Moreover, when I got to wifi setting under visible networks I see several duplicate entries for my wifi - one for each time I have given the password. Can someone please help me in this. If any more information is needed, please let me know.
output of sudo lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 04ca:0061 Lite-On Technology Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 1c4f:0002 SiGma Micro Keyboard TRACER Gamma Ivory
Bus 001 Device 002: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
output of sudo lspci
00:00.0 Host bridge: Intel Corporation Device 4c43 (rev 01)
00:02.0 VGA compatible controller: Intel Corporation Device 4c8a (rev 04)
00:08.0 System peripheral: Intel Corporation Device 4c11 (rev 01)
00:14.0 USB controller: Intel Corporation Device 43ed (rev 11)
00:14.2 RAM memory: Intel Corporation Device 43ef (rev 11)
00:16.0 Communication controller: Intel Corporation Device 43e0 (rev 11)
00:17.0 SATA controller: Intel Corporation Device 43d2 (rev 11)
00:1c.0 PCI bridge: Intel Corporation Device 43bc (rev 11)
00:1f.0 ISA bridge: Intel Corporation Device 4387 (rev 11)
00:1f.3 Audio device: Intel Corporation Device 43c8 (rev 11)
00:1f.4 SMBus: Intel Corporation Device 43a3 (rev 11)
00:1f.5 Serial bus controller [0c80]: Intel Corporation Device 43a4 (rev 11)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (10) I219-V (rev 11)
01:00.0 Non-Volatile memory controller: Kingston Technology Company, Inc. Device 500f (rev 03)
output of sudo lshw -c network
 *-network
       description: Ethernet interface
       product: Ethernet Connection (10) I219-V
       vendor: Intel Corporation
       physical id: 1f.6
       bus info: pci@0000:00:1f.6
       logical name: eno1
       version: 11
       serial: d8:bb:c1:64:2b:ae
       capacity: 1Gbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=5.11.0-43-generic firmware=0.6-4 latency=0 link=no multicast=yes port=twisted pair
       resources: irq:122 memory:92200000-9221ffff
  *-network
       description: Wireless interface
       physical id: 2
       bus info: usb@1:7
       logical name: wlx82316482c99f
       serial: 82:31:64:82:c9:9f
       capabilities: ethernet physical wireless
       configuration: broadcast=yes driver=r8188eu driverversion=5.11.0-43-generic ip=192.168.29.132 multicast=yes wireless=IEEE 802.11bgn
Automatically connecting to wi-fi through built-in method is still not working for some reason. I have found an alternative way to connect to wifi at startup(with a known BSSID as mentioned by @mchid above).
To get BSSID for your wifi please refer below question.
Getting BSSID and connecting to it is referred to from here.
nmcli -f in-use,ssid,bssid,signal,bars  dev wifi
Once you get the BSSID from above create a shell script connect.sh with below text
#!/bin/bash
nmcli d wifi connect xx:xx:xx:xx:xx:xx password "yourpassword"
replace xx:xx:xx:xx:xx:xx with your BSSID. save the file and change the file permission to make it executable
chmod +x connect.sh
In Ubuntu 20.04 there is an application "startup applications" that can be accessed from the GUI. add the above script file in startup application and now it connects automatically on startup.
