Suddenly after an update, I was unable to install anything or any updates.
I've tried to figure out what was causing it, I am not sure where the issue is but I would like to be able to install any updates.
After this issue happens I am able to go into the terminal by pressing alt+f2 and recently I found that I can get into the OS using the command startx but this is in some sort of limited graphics mode as it only covers 1 of my monitors, and the resolution is not right.
Before I've had issues when starting KDE (like a wallpaper not loading, or no DE at all basically) and have been able to solve that with restarting plasma,
I would do this using killall plasmashell and then plasmashell but this didn't work and got this error:
qt.qpa.xcb could not connect to display.
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimallegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb
fish: Job 1, 'plasmashell' terminated by signal SIGABRT (Abort)
not sure if this is relevant, but I'm just trying to give all the information I have
While trying to figure out what could be causing it, I also found that initramfs had some issues, I am not sure if it actually has issues, or it's something else.
I am kind of out of options and don't know what to do, is anyone able to help me?
Edit:
result of apt list --upgradable
code/unknown,stable 1.63.2-1639562499 amd64 [upgradable from: 1.63.1-1639448820]
heroic/unknown 1.11.0-beta.3.electron.15 amd64 [upgradable from: 1.11.0-alpha]
libegl-mesa0/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libegl1-mesa-dev/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libgbm1/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libgbm1/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
libgl1-mesa-dri/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libgl1-mesa-dri/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
libglapi-mesa/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libglapi-mesa/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
libglx-mesa0/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libglx-mesa0/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
libosmesa6/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
libosmesa6/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
libxatracker2/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
mesa-va-drivers/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
mesa-vdpau-drivers/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
mesa-vulkan-drivers/impish 21.3.2~kisak1~i amd64 [upgradable from: 21.3.1~kisak2~i]
mesa-vulkan-drivers/impish 21.3.2~kisak1~i i386 [upgradable from: 21.3.1~kisak2~i]
Edit 2:
apt update
Ign:1 cdrom://Kubuntu 21.10 _Impish Indri_ - Release amd64 (20211012) impish InRelease
Hit:2 cdrom://Kubuntu 21.10 _Impish Indri_ - Release amd64 (20211012) impish Release
Hit:3 http://archive.ubuntu.com/ubuntu impish InRelease
Hit:4 http://ppa.launchpad.net/fish-shell/release-3/ubuntu impish InRelease
Hit:6 http://archive.ubuntu.com/ubuntu impish-updates InRelease
Hit:7 http://packages.microsoft.com/repos/code stable InRelease
Hit:8 http://archive.ubuntu.com/ubuntu impish-security InRelease
Hit:9 http://ppa.launchpad.net/gerardpuig/ppa/ubuntu impish InRelease
Hit:10 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish InRelease
Ign:11 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/5.0 InRelease
Hit:12 https://repo.mongodb.org/apt/ubuntu focal/mongodb-org/5.0 Release
Hit:13 http://ppa.launchpad.net/obsproject/obs-studio/ubuntu impish InRelease
Hit:15 https://deb.nodesource.com/node_16.x impish InRelease
Hit:16 https://sourceforge.net/projects/madlinux/files/repo core InRelease
Reading package lists... Done
Building dependency tree... Done
19 packages can be upgraded. Run 'apt list --upgradable' to see them.
apt upgrade
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
gir1.2-peas-1.0 libllvm12:i386 libllvm12 libpeas-1.0-0 libpeas-common
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
code heroic libegl-mesa0 libegl1-mesa-dev libgbm1 libgbm1:i386 libgl1-mesa-dri:i386 libgl1-mesa-dri libglapi-mesa:i386 libglapi-mesa libglx-mesa0:i386 libglx-mesa0
libosmesa6 libosmesa6:i386 libxatracker2 mesa-va-drivers mesa-vdpau-drivers mesa-vulkan-drivers:i386 mesa-vulkan-drivers
19 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 229 MB of archives.
After this operation, 1.799 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 https://sourceforge.net/projects/madlinux/files/repo core/main amd64 code amd64 1.63.2-1639562499 [81,1 MB]
Get:3 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libegl-mesa0 amd64 21.3.2~kisak1~i [154 kB]
Get:4 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 libgbm1 i386 21.3.2~kisak1~i [80,2 kB]
Get:5 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libgbm1 amd64 21.3.2~kisak1~i [77,6 kB]
Get:6 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libgl1-mesa-dri amd64 21.3.2~kisak1~i [12,3 MB]
Get:7 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 libgl1-mesa-dri i386 21.3.2~kisak1~i [12,1 MB]
Get:8 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libosmesa6 amd64 21.3.2~kisak1~i [3.421 kB]
Get:9 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 libosmesa6 i386 21.3.2~kisak1~i [3.476 kB]
Get:10 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libglx-mesa0 amd64 21.3.2~kisak1~i [204 kB]
Get:11 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 libglx-mesa0 i386 21.3.2~kisak1~i [214 kB]
Get:12 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 libglapi-mesa i386 21.3.2~kisak1~i [83,8 kB]
Get:13 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libglapi-mesa amd64 21.3.2~kisak1~i [81,4 kB]
Get:14 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libegl1-mesa-dev amd64 21.3.2~kisak1~i [53,9 kB]
Get:15 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 libxatracker2 amd64 21.3.2~kisak1~i [2.056 kB]
Get:16 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 mesa-va-drivers amd64 21.3.2~kisak1~i [3.388 kB]
Get:17 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 mesa-vdpau-drivers amd64 21.3.2~kisak1~i [3.524 kB]
Get:18 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main amd64 mesa-vulkan-drivers amd64 21.3.2~kisak1~i [6.036 kB]
Get:19 http://ppa.launchpad.net/kisak/kisak-mesa/ubuntu impish/main i386 mesa-vulkan-drivers i386 21.3.2~kisak1~i [5.761 kB]
Get:2 https://sourceforge.net/projects/madlinux/files/repo core/main amd64 heroic amd64 1.11.0-beta.3.electron.15 [95,1 MB]
Fetched 229 MB in 33s (7.050 kB/s)
(Reading database ... 240115 files and directories currently installed.)
Preparing to unpack .../00-libegl-mesa0_21.3.2~kisak1~i_amd64.deb ...
Unpacking libegl-mesa0:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../01-libgbm1_21.3.2~kisak1~i_amd64.deb ...
De-configuring libgbm1:i386 (21.3.1~kisak2~i) ...
Unpacking libgbm1:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../02-libgbm1_21.3.2~kisak1~i_i386.deb ...
Unpacking libgbm1:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../03-libgl1-mesa-dri_21.3.2~kisak1~i_i386.deb ...
De-configuring libgl1-mesa-dri:amd64 (21.3.1~kisak2~i) ...
Unpacking libgl1-mesa-dri:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../04-libgl1-mesa-dri_21.3.2~kisak1~i_amd64.deb ...
Unpacking libgl1-mesa-dri:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../05-libosmesa6_21.3.2~kisak1~i_i386.deb ...
De-configuring libosmesa6:amd64 (21.3.1~kisak2~i) ...
Unpacking libosmesa6:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../06-libosmesa6_21.3.2~kisak1~i_amd64.deb ...
Unpacking libosmesa6:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../07-libglx-mesa0_21.3.2~kisak1~i_i386.deb ...
De-configuring libglx-mesa0:amd64 (21.3.1~kisak2~i) ...
Unpacking libglx-mesa0:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../08-libglx-mesa0_21.3.2~kisak1~i_amd64.deb ...
Unpacking libglx-mesa0:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../09-libglapi-mesa_21.3.2~kisak1~i_amd64.deb ...
De-configuring libglapi-mesa:i386 (21.3.1~kisak2~i) ...
Unpacking libglapi-mesa:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../10-libglapi-mesa_21.3.2~kisak1~i_i386.deb ...
Unpacking libglapi-mesa:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../11-libegl1-mesa-dev_21.3.2~kisak1~i_amd64.deb ...
Unpacking libegl1-mesa-dev:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../12-libxatracker2_21.3.2~kisak1~i_amd64.deb ...
Unpacking libxatracker2:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../13-mesa-va-drivers_21.3.2~kisak1~i_amd64.deb ...
Unpacking mesa-va-drivers:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../14-mesa-vdpau-drivers_21.3.2~kisak1~i_amd64.deb ...
Unpacking mesa-vdpau-drivers:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../15-mesa-vulkan-drivers_21.3.2~kisak1~i_amd64.deb ...
De-configuring mesa-vulkan-drivers:i386 (21.3.1~kisak2~i) ...
Unpacking mesa-vulkan-drivers:amd64 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../16-mesa-vulkan-drivers_21.3.2~kisak1~i_i386.deb ...
Unpacking mesa-vulkan-drivers:i386 (21.3.2~kisak1~i) over (21.3.1~kisak2~i) ...
Preparing to unpack .../17-code_1.63.2-1639562499_amd64.deb ...
Unpacking code (1.63.2-1639562499) over (1.63.1-1639448820) ...
Preparing to unpack .../18-heroic_1.11.0-beta.3.electron.15_amd64.deb ...
Unpacking heroic (1.11.0-beta.3.electron.15) over (1.11.0-alpha) ...
Setting up mesa-vulkan-drivers:amd64 (21.3.2~kisak1~i) ...
Setting up mesa-vulkan-drivers:i386 (21.3.2~kisak1~i) ...
Setting up mesa-vdpau-drivers:amd64 (21.3.2~kisak1~i) ...
Setting up libgbm1:amd64 (21.3.2~kisak1~i) ...
Setting up libgbm1:i386 (21.3.2~kisak1~i) ...
Setting up libxatracker2:amd64 (21.3.2~kisak1~i) ...
Setting up heroic (1.11.0-beta.3.electron.15) ...
Setting up libglapi-mesa:amd64 (21.3.2~kisak1~i) ...
Setting up libglapi-mesa:i386 (21.3.2~kisak1~i) ...
Setting up mesa-va-drivers:amd64 (21.3.2~kisak1~i) ...
Setting up libosmesa6:amd64 (21.3.2~kisak1~i) ...
Setting up libosmesa6:i386 (21.3.2~kisak1~i) ...
Setting up libegl1-mesa-dev:amd64 (21.3.2~kisak1~i) ...
Setting up code (1.63.2-1639562499) ...
Setting up libgl1-mesa-dri:amd64 (21.3.2~kisak1~i) ...
Setting up libgl1-mesa-dri:i386 (21.3.2~kisak1~i) ...
Setting up libegl-mesa0:amd64 (21.3.2~kisak1~i) ...
Setting up libglx-mesa0:amd64 (21.3.2~kisak1~i) ...
Setting up libglx-mesa0:i386 (21.3.2~kisak1~i) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.34-0ubuntu3) ...
Processing triggers for shared-mime-info (2.1-1) ...
Processing triggers for mailcap (3.69ubuntu1) ...
Processing triggers for desktop-file-utils (0.26-1ubuntu2) ...
After this my system stopped booting properly
Edit 3:
Not sure if this is relevant anymore, but I've found the messages with initramfs, this happens during an apt upgrade
Setting up linux-firmware (1.201.3) ...
update-initramfs: Generating /boot/initrd.img-5.13.0-22-generic
W: Possible missing firmware /lib/firmware/amdgpu/vangogh_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_ta.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_smc.bin for module amdgpu
update-initramfs: Generating /boot/initrd.img-5.13.0-19-generic
I've removed some ppa's, not sure if I'm doing it correctly, but I don't think it solves it, I'm also not sure which I will need to keep to keep my system working
here's a list of the available updates that I have, So I assume that one of them is causing the problem Available updates
After removing most PPA's I do get a more normal system update screen, with the kubuntu logo and loading updates xx% but after that is done I get an error saying:
[1.241888] nvme 0000:04:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x0017 address=0xfedfb000 flags=0x0000]
I assume I'm getting closer to resolving it, but it might just be a weird combination of multiple problems?
