I want to add my Google account, but the settings page instantly freezes when I click on Google. The same happens for the Microsoft, Flickr, foursquare and Microsoft exchange options. So everything that uses SSO? The other options give a little system pop-up where I can enter my credentials and connect without issue.
On my first clean install, I could use my Google account without any issues. This sadly lasted only for 2 days.
I've tried:
  • Disabling ipv6
  • Rebooting my router
  • Reinstalling gnome
  • Use a VPN
  • Run gnome-control-center from the terminal to collect some logs, which resulted in this:
(gnome-control-center:10442): dconf-WARNING **: 14:13:23.381: Unable to open /usr/local/share/dconf/profile/user: Permission denied
bwrap: Can't find source path /usr/local/share: Permission denied
This output is generated when I open gnome settings, after that nothing, not even when it eventually crashes. I collect the output with command gnome-control-center > ~/errorerror.txt 2>&1
  • Suggestions?
BugSquanch
  • 191
I'm not sure about the cause, but the WEBKIT_FORCE_SANDBOX answer didn't fix it for me, instead I had to do the following
  1. Open a Terminal
  2. Enter export WEBKIT_DISABLE_COMPOSITING_MODE=1 press enter
  3. Enter gnome-control-center and proceed with adding the account without a crash.
samy
  • 445
In a terminal, run:
export WEBKIT_FORCE_SANDBOX=0
That should get the settings dialogs to work. It appears that the GNOME Control Center ("Settings") -> Online Accounts dialogs use WebKit to prompt for additional details. WebKit is affected by a bug in at a particular package release. A bug report from Mageia has additional details: https://bugs.mageia.org/show_bug.cgi?id=30041. I was able to reproduce and test the work-around on Parrot OS 5.0.
Missing from this Answer are confirmation that this work-around succeeds with Ubuntu and a link to an authoritative bug report to track the fix upstream. This should be a temporary work-around until the patched package or packages roll forward.
D.A.
  • 167
Turning of 2fa while attaching (then turning it back on afterwards) finally did it for me. In on of 4 accounts I had this (or similar in symptoms) issue. All have 2fa.
