I tried some of the available solution, but hard luck anyone able to provide me the solution.
- Unmet dependencies installing vim or vim-tiny
- Unmet dependencies. Try 'apt --fix-broken install'
- How to fix unmet dependencies for udev:amd64 error on Ubuntu 18.04?
sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
vim-runtime : Breaks: vim-tiny (2:8.2.2434-3ubuntu3.1) but 2:8.2.2434-3ubuntu3 is installed
vim-tiny : Depends: vim-common (= 2:8.2.2434-3ubuntu3) but 2:8.2.2434-3ubuntu3.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I tried even re-installing & installing the vim-tiny but not able to do the same. it gives me the error
sudo apt-get install --reinstall vim=2:8.2.2434-3ubuntu3.1
vim-runtime : Breaks: vim-tiny (< 2:8.2.2434-3ubuntu3.1) but 2:8.2.2434-3ubuntu3 is to be installed
vim-tiny : Depends: vim-common (= 2:8.2.2434-3ubuntu3) but 2:8.2.2434-3ubuntu3.1 is to be installed
I am also attaching the output of sudo apt-get update
sudo apt-get update
Hit:1 http://in.archive.ubuntu.com/ubuntu impish InRelease
Get:2 http://in.archive.ubuntu.com/ubuntu impish-updates InRelease [110 kB]
Get:3 http://in.archive.ubuntu.com/ubuntu impish-backports InRelease [101 kB]
Get:4 http://in.archive.ubuntu.com/ubuntu impish-updates/main amd64 DEP-11 Metadata [18.8 kB]
Get:5 http://in.archive.ubuntu.com/ubuntu impish-updates/universe amd64 DEP-11 Metadata [4,476 B]
Get:6 http://in.archive.ubuntu.com/ubuntu impish-backports/universe amd64 DEP-11 Metadata [9,288 B]
Hit:7 http://dl.google.com/linux/chrome/deb stable InRelease
Get:8 http://security.ubuntu.com/ubuntu impish-security InRelease [110 kB]
Get:10 http://security.ubuntu.com/ubuntu impish-security/main amd64 DEP-11 Metadata [6,428 B]
Get:11 http://security.ubuntu.com/ubuntu impish-security/universe amd64 DEP-11 Metadata [2,312 B]
Hit:9 https://packagecloud.io/slacktechnologies/slack/debian jessie InRelease
Fetched 363 kB in 2s (167 kB/s)
and sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
vim-tiny
Suggested packages:
indent
The following packages will be upgraded:
vim-tiny
1 upgraded, 0 newly installed, 0 to remove and 43 not upgraded.
3 not fully installed or removed.
Need to get 0 B/675 kB of archives.
After this operation, 1,024 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 286916 files and directories currently installed.)
Preparing to unpack .../vim-tiny_2%3a8.2.2434-3ubuntu3.1_amd64.deb ...
Unpacking vim-tiny (2:8.2.2434-3ubuntu3.1) over (2:8.2.2434-3ubuntu3) ...
dpkg: error processing archive /var/cache/apt/archives/vim-tiny_2%3a8.2.2434-3ub
untu3.1_amd64.deb (--unpack):
trying to overwrite '/usr/share/vim/vim82/doc/help.txt', which is also in package vim-runtime 2:8.2.2434-3ubuntu3.1
/var/cache/apt/archives/vim-tiny_2%3a8.2.2434-3ubuntu3.1_amd64.deb
How to fix this error?
UBUNTU :- Ubuntu 21.10
Windowing System :- Wayland
