I am trying to install vi and vim
I initially had vi instlled, and could not install vim, then I removed vi, and now I cannot install both.
I watch all threads in internet, that says you should update, uninstall or purge, then reinstall, but none are working.
Here are the logs:
[root@artik ~]# apt-get install vi.tiny
Reading package lists... Done
Building dependency tree
E: Unable to locate package vi.tiny
E: Couldn't find any package by glob 'vi.tiny'
E: Couldn't find any package by regex 'vi.tiny'
[root@artik ~]# apt-get install vim
vim : Depends: vim-common (= 2:8.1.0788-0york0~16.04) but 2:8.1.0837-0york0~16.04 is to be installed
Depends: vim-runtime (= 2:8.1.0788-0york0~16.04) but 2:8.1.0837-0york0~16.04 is to be installed
now, file /etc/apt/sources.list
[root@artik ~]# cat /etc/apt/sources.list
deb http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial main universe
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-security main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-security main universe
deb http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main universe
deb-src http://ports.ubuntu.com/ubuntu-ports/ xenial-updates main universe
deb [arch=armhf] https://download.docker.com/linux/ubuntu xenial stable
# deb-src [arch=armhf] https://download.docker.com/linux/ubuntu xenial stable
deb http://archive.ubuntu.com/ubuntu xenial main universe
# deb-src http://archive.ubuntu.com/ubuntu xenial main universe
I am running ubuntu on Artik board
EDIT: Inside /etc/apt/sources.list.d/ I have:
[root@artik ~]# ls /etc/apt/sources.list.d/
artik-e2e-source.list
artik-e2e-source.list.save
artik-platform-artik533s-sources.list
artik-platform-artik533s-sources.list.save
jonathonf-ubuntu-vim-xenial.list
jonathonf-ubuntu-vim-xenial.list.save
nodesource.list
nodesource.list.save
and apt-cache
[root@artik ~]# apt-cache policy vim vim-common
vim:
Installed: (none)
Candidate: 2:8.1.0788-0york0~16.04
Version table:
2:8.1.0788-0york0~16.04 500
500 http://ppa.launchpad.net/jonathonf/vim/ubuntu xenial/main armhf Packages
2:7.4.1689-3ubuntu1.2 500
500 http://ports.ubuntu.com/ubuntu-ports xenial-security/main armhf Packages
500 http://ports.ubuntu.com/ubuntu-ports xenial-updates/main armhf Packages
2:7.4.1689-3ubuntu1 500
500 http://ports.ubuntu.com/ubuntu-ports xenial/main armhf Packages
vim-common:
Installed: (none)
Candidate: 2:8.1.0837-0york0~16.04
Version table:
2:8.1.0837-0york0~16.04 500
100 /var/lib/dpkg/status
EDIT 2:
When I do apt-get update I get an error, I don't know if it is important:
Err:7 http://archive.ubuntu.com/ubuntu xenial/main armhf Packages
404 Not Found [IP: 91.189.88.162 80]
