I have Nvidia GeFore GT710 Graphics Card and facing issues with the driver installation. Though I am getting an option to nvidia-driver-470 tested version to install. Once installation, Graphic Card is not getting initiated and resolution is some 600X. System is only working on Nouveau display driver which is not performing at all and very lag in resolution. Pleas help.
Asked
Active
Viewed 2.0k times
Remove all the nvidia packages.
sudo apt update sudo apt upgrade sudo apt autoremove sudo apt-get remove --purge nvidia* sudo apt-get remove --purge "nvidia*"If you have added an Nvidia PPA to
/etc/apt/sources.listor/etc/apt/sources.list.d/remove that PPA by prefacing its line in sources.list with a#to comment it out. Runsudo apt updateto refresh the list of available software.Reboot with
sudo reboot/etc/apt/sources.list.d/ubuntu.sourcesRun the following command to automatically select and install the Nvidia proprietary graphics driver and reboot.
sudo ubuntu-drivers install && sudo reboot
After you have installed the proprietary Nvidia graphics driver with the above command it may be updated to a more up-to-date proprietary Nvidia graphics driver package by the normal software update activity.
karel
- 122,292
- 133
- 301
- 332
