Problem
I want to install nvidia driver in my laptop. My laptop is always stuck on blackscreen after installing nvidia driver and executing reboot. I have tried tried different approaches and many nvidia driver versions. However, the problem is always here.
My ubuntu18.04 has two kernel 5.4.0-122 and 5.4.0-117. I installed nvidia driver by software update. Then the output is normal after executing nvidia-smi. But when I reboot my laptop, a probelm appearred. If I choose 5.4.0-122 kernel, the laptop will be stuck in black screen. If I choose 5.4.0-117 kernel, NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running will appear in shell after executing nvidia-smi.
I will describe below some key information about my laptop. Hope someone could help me with this perplexing problem. Thanks!
My laptop information
  • sudo lshw -class video
 *-display UNCLAIMED
       description: 3D controller
       product: GP107M [GeForce GTX 1050 Mobile]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress bus_master cap_list
       configuration: latency=0
       resources: memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:df000000-df07ffff
  *-display
       description: VGA compatible controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 04
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
       configuration: driver=i915 latency=0
       resources: irq:131 memory:dd000000-ddffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
Installation approaches
Preparation before installation
Disable secure boot and disable the system's own Nouveau graphics card driver
Installation
Add ppa source
Open Software Update --> Additional Programs --> Click on one of the drivers to install it --> Finish the installation --> reboot In addition, I tried nvidia-driver-515, nvidia-driver-510, nvidia-driver-470, nvidia-driver-418 and nvidia-driver-390.
Problem solution
I have tried Fixing Ubuntu Freezing at Boot Time, but it does not work.
I reinsatll my OS from ubuntu18.04 to ubuntu20.04. The thing become simple. I install nvidia driver just from the "software and updates/additional drivers" and select the latest "tested" one. It works!
