How I can tell what the process name of a window is? I need a command that I can run on the terminal. I'm using X11, not Wayland.
Per your request on the other question, here is my answer again:
I'm sure there is a cleaner way of doing it, but for your second question you can try this:
xprop _NET_WM_PID | sed 's/_NET_WM_PID(CARDINAL) = //' | ps `cat`This will make your cursor a cross with which you can click on an open window. It will report the PID and command in the terminal you ran it in.
In general, xprop and xwininfo will provide you with a lot of information about an open window.
The "apostrophes" I used for surrounding cat are the ~ key on my keyboard without pressing shift. This should give you some more info on the subject:
- 1,139
You can try xprop | grep WM_CLASS and then click on the window you are interested in.
Examples:
#> xprop | grep WM_CLASS
WM_CLASS(STRING) = "gedit", "Gedit"
WM_CLASS(STRING) = "gcalctool", "Gcalctool"
And since we need the PID, we need to do xprop | grep PID.
Run this command in a terminal:
xprop | awk '/PID/ {print $3}'
Your mouse pointer will be replaced with crosshairs; select the window you're interested in.
This method shows just the PID of the process who owns that window (which appears to be what you want).
- 119,640
- 6,908
- 4
- 40
- 48
You can get process info using:
$ ps -f --pid $(xprop _NET_WM_PID | grep -o '[0-9]*')
- 1,413
Running xprop | awk '/_NET_WM_PID\(CARDINAL\)/{print $NF}' and clicking the window you want the PID of will print the PID to the terminal.
- 258
