I'm using Ubuntu 20.04 LTS on HP Laptop.
I'm experiencing some issues with certain key combinations in my laptop keyboard.
Following key combinations are not working.
  • Right Shift Key + E
  • Ctrl + C
Ctrl + other keys are working, also, c is working independently. Right Shift + other keys are working. Left Shift + E is also working.
Can anyone help me to identify if it is a configuration issue or an indication of an upcoming hardware failure?
I have used some diagnosis tools and identified these combinations ar re not detected. Would it be a hardware issue when these keys are working independently and in combination with other keys.
niyasc
  • 176
To assess whether the keyboard is failing, you could use any application to monitor key presses. See options here, here, here:
  1. screenkey
  2. sudo evtest
  3. xev
You can perform further evaluations by:
  1. Booting from a Live USB and/or Windows. If the problem stems from your Ubuntu configuration, these should work.
  2. Using another keyboard in your Ubuntu.
All this should suffice to give a clear answer.
Related
  1. https://wiki.ubuntu.com/LaptopTesting/Keycodes
  2. https://manpages.ubuntu.com/manpages/focal/man1/showkey.1.html
I tried the tools suggested in the other answer, and found the mentioned key combinations are not detected, even though they are detected independently.
I tried pressing the keys a little bit harder, and now the key combinations are working.
So, I think there was some contact issue in the keyboard because of dust.
niyasc
  • 176
