I have a snapcraft.yaml as below:
version: git
summary: A Telegram Terminal Application
description: |
  `tgcli` is a terminal application to send
  message with bots on Telegram.
base: core18 confinement: devmode
parts: tgcli: plugin: rust source: .
apps: tgcli: command: bin/tgcli
I’m trying to build a Rust terminal application. I am here in the documentation. I run snapcraft. It tries to connect archive.ubuntu.com and security.ubuntu.com, yet fails to do so after a couple of minutes. The full output is:
Launching a container.
Build environment is in unknown state, cleaning first.
Waiting for container to be ready
Created symlink /etc/systemd/system/dbus-org.freedesktop.network1.service → /lib/systemd/system/systemd-networkd.service.
Waiting for network to be ready...
Err:1 http://archive.ubuntu.com/ubuntu bionic InRelease
  Could not connect to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
Err:2 http://security.ubuntu.com/ubuntu bionic-security InRelease
  Could not connect to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
Err:3 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Reading package lists... Done
W: Failed to fetch http://security.ubuntu.com/ubuntu/dists/bionic-security/InRelease  Could not connect to security.ubuntu.com:80 (2001:67c:1562::18). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1562::15). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Could not connect to security.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.39), connection timed out Could not connect to security.ubuntu.com:80 (91.189.88.152), connection timed out Could not connect to security.ubuntu.com:80 (91.189.91.38), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic/InRelease  Could not connect to archive.ubuntu.com:80 (2001:67c:1360:8001::23). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (2001:67c:1360:8001::24). - connect (101: Network is unreachable) Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
W: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/bionic-updates/InRelease  Could not connect to archive.ubuntu.com:80 (91.189.88.142), connection timed out Could not connect to archive.ubuntu.com:80 (91.189.88.152), connection timed out
W: Some index files failed to download. They have been ignored, or old ones used instead.
Building dependency tree
Package udev is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
However the following packages replace it:
  systemd
E: Unable to locate package dirmngr E: Package 'udev' has no installation candidate E: Unable to locate package fuse An error occurred when trying to execute 'apt-get install dirmngr udev fuse --yes' with 'LXD': returned exit code 100.
I have tried to solve it, I have seen solutions like in this one, yet it does not work. I think it’s because snaps work in a confined environment.
I also tried removing lxd and rebuilding my snap so that it reinstalls and reconfigures lxd but that didn't work either.
How can I solve this?
Thanks in advance.
