I use laptop-mode-tools to save battery on my Asus TUF A17. I works fine but not for the hard disk : this one is going too much to sleep and wake up after every 10 seconds. So the Load_Cycle_Count is increasing too much.
meloli@Asus-A17:~$ sudo smartctl -a /dev/sda | grep Load_Cycle_Count
193 Load_Cycle_Count 0x0032 098 098 000 Old_age Always - 4321
I tried sudo hdparm -B 255 /dev/sda or sudo hdparm -B 254 /dev/sda wbut it does nothing...
The only things who seems to work is using spindown time
meloli@Asus-A17:~$ sudo hdparm -B 254 /dev/sda
/dev/sda:
setting Advanced Power Management level to 0xfe (254)
APM_level = 254
meloli@Asus-A17:~$ sudo hdparm -S 242 /dev/sda
/dev/sda:
setting standby to 242 (1 hours)
I tried something like this in /etc/hdparm.conf but I does nothin when using battery.
/dev/sda {
# apm = 127
apm_battery = 254
spindown_time = 241
command_line {
hdparm -S 241 /dev/sda
Everything works fine when using AC.
How to get my hard disk not to go to sleep too quickly when using laptop-mode-tools ?
Thank you.
