I'm running Ubuntu 20.4 desktop and I have to run "xset r on" from command line each time I log in otherwise holding arrow or del keys does not work (in repeated mode).
I added "xset r on" at the end of .profile file in my home directory but that does not seem to work.
Is there a better way to run this command at the time of boot up or login?
PS: This problem seems new after I moved to 20.04 and curious if there is a setting that I may have missed for this one.
Here is my .profile file:
    # the default umask is set in /etc/profile; for setting the umask
# for ssh logins, install and configure the libpam-umask package.
#umask 022
if running bash
if [ -n "$BASH_VERSION" ]; then # include .bashrc if it exists if [ -f "$HOME/.bashrc" ]; then . "$HOME/.bashrc" fi fi
set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then PATH="$HOME/bin:$PATH" fi
if [ -d "$HOME/.local/bin" ] ; then PATH="$HOME/.local/bin:$PATH" fi
xset r on
Pankaj
  • 303
I am using the .bashrc file in the same directory to add commands that should be executed on terminal open:
export PATH="$PATH:/home/usr/schmok"
/usr/bin/screenfetch -d "-disk;-pkgs;-shell;"
xset r on
But that cures the symptom, not the source.
kanehekili
  • 7,426
