On both Ubuntu 21.10 and Ubuntu 20.04 LTS, display update pauses for 2 seconds multiple times per minute.
I've been experiencing what appears to be the same issue as this question, first on Ubuntu 20.04 LTS, and now again on Ubuntu 21.10. The issue occurs very frequently and I find it so frustrating that it makes the computer almost unusable.
Ubuntu 21.10
In troubleshooting on Ubuntu 21.10, I suspect this issue is related to the Xorg process and is specific to kernel Linux 5.13.0-21-generic. This combination is the default after installing and upgrading Ubuntu 21.10. It does not appear to occur when selecting the previous kernel Linux 5.13.0-20-generic or when using Wayland, rather than Xorg.
In my case, the pauses occur only while moving the cursor or upon typing on the keyboard. Each pause is approximately 2 seconds and pauses all display updates, including the cursor movement in the Ubuntu GUI, typing entry, video playback, etc. When it is happening, the pause happens multiple times every minute. The issue does not appear related to recovering from idle input: It does not occur every time that I resume cursor or keyboard input, and does occur randomly after I have already been providing input for some time. Sometimes the computer can go for longer periods without this issue occurring and it is not clear why.
On a recent (last weekend) fresh install of Ubuntu 21.10, this behavior appeared to start only after upgrading Ubuntu via sudo apt dist-upgrade. The issue had previously occurred on Ubuntu 20.04 LTS and recurred after a reinstall of Ubuntu 20.04 LTS.
In troubleshooting on Ubuntu 21.10, I have identified that each pause is consistently matched with a spike in CPU activity for the Xorg process, as seen in top. Xorg CPU is normally low between the pauses: 0% to 0.3% with occasional spikes to 4%. Upon each pause, and only upon a pause Xorg spikes to 30% to 60% CPU. Xorg VIRT is around 24.8g as shown in top. No other process is using as much CPU. free shows 57Gi Mem available and 2Gi Swap free.
The issue occurs even with no user applications open, with Bluetooth and Wi-Fi off, and no peripherals connected, and occurs both when connected to power and when on battery.
My computer is a Lenovo Thinkpad X1 Extreme Gen 2, Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz, 64GB RAM, NVIDIA GeForce GTX 1650 Mobile. Swap is set at the default 2GB, but remains completely free and unused while this issue occurs. Kernel is Linux 5.13.0-21-generic.
It took me several weeks to find this related issue (vs many issues about more persistent freezes of the GUI), so including some keywords I had searched: pausing cursor and keyboard, pointer stopping, display stuttering.
The issue appears to require the combination of kernel Linux 5.13.0-21-generic and Xorg:
  • After booting with Advanced options for Ubuntu and selecting the previous kernel Linux 5.13.0.20-generic and keeping the default Ubuntu (not Ubuntu on Xorg), this issue did not recur (over some limited use), but my external display is no longer recognized over USB-C. In this configuration, Xorg is not active as seen in top.
  • After booting to the default kernel Linux 5.13.0.21-generic, but selecting Ubuntu on Wayland in the settings of the login screen, this issue did not recur (over some limited use), but the Ubuntu GUI crashes upon plugging in my external display over USB-C. In this configuration, Xorg is not active as seen in top.
  • After booting with Advanced options for Ubuntu and selecting the previous kernel Linux 5.13.0.20-generic and selecting Ubuntu on Xorg, this issue did not recur (over some limited use).
Looking back at the combination with the issue (booting with kernel Linux 5.13.0-21-generic and Xorg), dmesg consistently shows several entries [drm:nv_drm_master_set [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to grab modeset ownership around 24 seconds. These entries are not present on dmesg during the other 3 combinations of kernel and Xorg/Wayland. These entries occur even when the pausing symptom has not yet occurred, and it is unclear if the entries are related to the pausing issue.
Ubuntu 20.04 LTS
This issue also occurs on Ubuntu 20.04 TLS which has the Xorg process and kernel Linux 5.11.0-38-generic by default after installing and upgrading. The Wayland option does not appear to be available during logon.
I appreciate any suggestions for further troubleshooting.
