I recently got a Dell Precision 3450 with ubuntu 20.04, and upgraded to ubuntu 21.10 in two steps (20.04 -> 21.04 -> 21.10). This required upgrading the file /usr/lib/os-release by hand, as described here, probably because of customizations by Dell to the OEM install.
In any case, the system works fine now, with one exception. When I type curl in the terminal (which I installed after the second upgrade), I get the following error message.
curl: error while loading shared libraries: libldap_r-2.4.so.2: cannot open shared object file: No such file or directory
So it seems like curl is trying to load libldap in version 2.4, which is not installed. I asked a friend who also has ubuntu 21.10 and curl works fine for him with the same versions of curl (7.74.0-1.3ubuntu2) and libldap (2.5.6+dfsg-1~exp1ubuntu1).
I also tried to install an older version of libldap -- specifically the file libldap-2.4-2_2.4.57+dfsg-2ubuntu1_amd64.deb from the 21.04 repo -- but after doing that, curl gives me a new error message:
curl: symbol lookup error: curl: undefined symbol: curl_multi_poll, version URL_OPENSSL_4
so that doesn't help.
Does anybody have an idea what's going on?
I don't understand understand how dynamic linking works, and googling didn't really help. This site suggests to simply do sudo /sbin/ldconfig -v but that didn't work.
I don't know if the problem is specific to the OEM install of ubuntu and "forced" ugprade, but the surprising thing is that everything except curl seems to work.
EDIT:
Here is the output of ldd $(type -p curl) on the system where curl works.
 linux-vdso.so.1 (0x00007ffe043f1000)
libcurl.so.4 => /lib/x86_64-linux-gnu/libcurl.so.4 (0x00007fc870cbb000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc870c9f000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc870a77000)
libnghttp2.so.14 => /lib/x86_64-linux-gnu/libnghttp2.so.14 (0x00007fc870a49000)
libidn2.so.0 => /lib/x86_64-linux-gnu/libidn2.so.0 (0x00007fc870a28000)
librtmp.so.1 => /lib/x86_64-linux-gnu/librtmp.so.1 (0x00007fc870a09000)
libssh.so.4 => /lib/x86_64-linux-gnu/libssh.so.4 (0x00007fc87099a000)
libpsl.so.5 => /lib/x86_64-linux-gnu/libpsl.so.5 (0x00007fc870986000)
libssl.so.1.1 => /lib/x86_64-linux-gnu/libssl.so.1.1 (0x00007fc8708ee000)
libcrypto.so.1.1 => /lib/x86_64-linux-gnu/libcrypto.so.1.1 (0x00007fc870613000)
libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007fc8705c1000)
libldap-2.5.so.0 => /lib/x86_64-linux-gnu/libldap-2.5.so.0 (0x00007fc870562000)
liblber-2.5.so.0 => /lib/x86_64-linux-gnu/liblber-2.5.so.0 (0x00007fc87054f000)
libbrotlidec.so.1 => /lib/x86_64-linux-gnu/libbrotlidec.so.1 (0x00007fc870541000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc870db5000)
libunistring.so.2 => /lib/x86_64-linux-gnu/libunistring.so.2 (0x00007fc8703bf000)
libgnutls.so.30 => /lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007fc8701da000)
libhogweed.so.6 => /lib/x86_64-linux-gnu/libhogweed.so.6 (0x00007fc870192000)
libnettle.so.8 => /lib/x86_64-linux-gnu/libnettle.so.8 (0x00007fc87014a000)
libgmp.so.10 => /lib/x86_64-linux-gnu/libgmp.so.10 (0x00007fc8700c7000)
libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007fc86fffe000)
libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007fc86ffd1000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007fc86ffcb000)
libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007fc86ffbb000)
libsasl2.so.2 => /lib/x86_64-linux-gnu/libsasl2.so.2 (0x00007fc86ffa0000)
libbrotlicommon.so.1 => /lib/x86_64-linux-gnu/libbrotlicommon.so.1 (0x00007fc86ff7d000)
libp11-kit.so.0 => /lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007fc86fe43000)
libtasn1.so.6 => /lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007fc86fe2d000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007fc86fe24000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fc86fe0f000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc86fe0a000)
libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x00007fc86fdfe000)
And here's the output of ldd $(type -p curl) on the system where curl doesn't work.
linux-vdso.so.1 (0x00007fffa0f86000)
libcurl.so.4 => /usr/lib/dcaenabler/libcurl.so.4 (0x00007fc1b789f000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc1b7883000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc1b765b000)
libnghttp2.so.14 => /lib/x86_64-linux-gnu/libnghttp2.so.14 (0x00007fc1b762d000)
libidn2.so.0 => /lib/x86_64-linux-gnu/libidn2.so.0 (0x00007fc1b760c000)
librtmp.so.1 => /lib/x86_64-linux-gnu/librtmp.so.1 (0x00007fc1b75ed000)
libpsl.so.5 => /lib/x86_64-linux-gnu/libpsl.so.5 (0x00007fc1b75d7000)
libssl.so.1.1 => /usr/lib/dcaenabler/libssl.so.1.1 (0x00007fc1b734a000)
libcrypto.so.1.1 => /usr/lib/dcaenabler/libcrypto.so.1.1 (0x00007fc1b6e7f000)
libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007fc1b6e2d000)
libldap_r-2.4.so.2 => not found
liblber-2.4.so.2 => not found
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc1b6e26000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc1b7b74000)
libunistring.so.2 => /lib/x86_64-linux-gnu/libunistring.so.2 (0x00007fc1b6ca4000)
libgnutls.so.30 => /lib/x86_64-linux-gnu/libgnutls.so.30 (0x00007fc1b6abf000)
libhogweed.so.6 => /lib/x86_64-linux-gnu/libhogweed.so.6 (0x00007fc1b6a77000)
libnettle.so.8 => /lib/x86_64-linux-gnu/libnettle.so.8 (0x00007fc1b6a31000)
libgmp.so.10 => /lib/x86_64-linux-gnu/libgmp.so.10 (0x00007fc1b69ac000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc1b69a7000)
libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007fc1b68de000)
libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007fc1b68b1000)
libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007fc1b68ab000)
libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007fc1b689d000)
libp11-kit.so.0 => /lib/x86_64-linux-gnu/libp11-kit.so.0 (0x00007fc1b6761000)
libtasn1.so.6 => /lib/x86_64-linux-gnu/libtasn1.so.6 (0x00007fc1b674b000)
libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007fc1b6744000)
libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fc1b672f000)
libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x00007fc1b6723000)
Output of which curl on the problematic system:
/usr/bin/curl
Output of aptitude search ~o on problematic system:
i   dca-enabler        - Provides the DELL Client Agent Enabler software.
i   dca-enabler-packages        - Provides the DELL Client Agent Enabler Dependencies.
i   dell-canonical-logo        - Install the dell-canonical-logo in gnome-control-center.
i   dell-super-key        - Disables the super key by default.
i   djvu2pdf        - Script to convert Djvu files to PDF files
i   fist        - Factory Install System Test
i A gir1.2-unity-5.0        - GObject introspection data for the Unity library
i A linux-headers-5.10.0-1031-oem                                                          - Linux kernel headers for version 5.10.0 on 64 bit x86 SMP
i A linux-headers-5.10.0-1050-oem                                                          - Linux kernel headers for version 5.10.0 on 64 bit x86 SMP
i A linux-headers-oem-20.04b                                                               - OEM Linux kernel headers
i A linux-image-5.10.0-1031-oem                                                            - Signed kernel image oem
i A linux-image-5.10.0-1050-oem                                                            - Signed kernel image oem
i A linux-image-oem-20.04b        - OEM Linux kernel image
i A linux-modules-5.10.0-1031-oem                                                          - Linux kernel extra modules for version 5.10.0 on 64 bit x86 SMP
i A linux-modules-5.10.0-1050-oem                                                          - Linux kernel extra modules for version 5.10.0 on 64 bit x86 SMP
i   linux-oem-20.04b        - Complete OEM Linux kernel and headers
i A linux-oem-5.10-headers-5.10.0-1031                                                     - Header files related to Linux kernel version 5.10.0
i A linux-oem-5.10-headers-5.10.0-1050                                                     - Header files related to Linux kernel version 5.10.0
i A linux-oem-5.10-tools-5.10.0-1031                                                       - Linux kernel version specific tools for version 5.10.0-1031
i   linux-tools-5.10.0-1031-oem                                                            - Linux kernel version specific tools for version 5.10.0-1031
i   lsd        - An ls command with a lot of pretty colors.
i   manage-distro-upgrade        - Disable upgrade for OEM.
i A manage-estar-settings        - Energy Star related settings
i A oem-fix-misc-cnl-tlp-estar-conf                                                        - customized configuration for tlp.
i   oem-ouagadougou-meta        - Meta package for the OEM mainstreams image.
i   oem-release        - Show oem release version
i   oem-somerville-butterfree-meta                                                         - hardware support for Somerville Butterfree platform
i   oem-somerville-factory-butterfree-meta                                                 - hardware support for Somerville Butterfree platform (factory)
i   oem-somerville-factory-meta                                                            - hardware support for Somerville platform
i   oem-somerville-meta        - hardware support for Somerville platform
i A oem-somerville-partner-archive-keyring                                                 - Somerville project keyrings
i   slack-desktop        - Slack Desktop
i   sosreport-oem        - OEM image releated sosreport plugins and utilities.
aptitude search ~b outputs nothing -- no broken packages.
Here's the output of tree /usr/local/:
/usr/local/
├── bin
├── etc
├── games
├── include
├── lib
│   └── python3.9
│       └── dist-packages
├── man -> share/man
├── sbin
├── share
│   ├── ca-certificates
│   ├── fonts
│   ├── man
│   ├── sgml
│   │   ├── declaration
│   │   ├── dtd
│   │   ├── entities
│   │   ├── misc
│   │   └── stylesheet
│   ├── texmf
│   └── xml
│       ├── declaration
│       ├── entities
│       ├── misc
│       └── schema
├── src
└── stow
Output of dpkg -S /usr/lib/dcaenabler/libcurl.so.4 /usr/lib/dcaenabler/libssl.so.1.1 /usr/lib/dcaenabler/libcrypto.so.1.1:
dca-enabler-packages: /usr/lib/dcaenabler/libcurl.so.4
dca-enabler-packages: /usr/lib/dcaenabler/libssl.so.1.1
dca-enabler-packages: /usr/lib/dcaenabler/libcrypto.so.1.1
Most likely related: I just observed repeated lines of the form
10 Nov 2021 15:36:59    j-dell  env[10851]  /usr/sbin/dcae: error while loading shared libraries: libldap_r-2.4.so.2: cannot open shared object file: No such file or directory
in /var/log/syslog. If I run dcae on the command line I get the error message
just as with curl.
Analysis of ldd /usr/bin/curl output shows that Dell packages cause this issue. To fix the system we need to remove them by
sudo apt-get purge --autoremove dca-enabler-packages dca-enabler
Note: tool for ldd output analysis is discussed in this Q&A. It helped me a lot to detect your problem programmatically.
N0rbert
  • 103,263
I found another simple solution for this issue,use snap version of curl sudo snap install curl, i just run into this issue on my dell pc and snap version works fine for me
