How to type Bengali using Ubuntu 12.04. I had installed IBus but unable to find the list of languages from the drop down list when I try to add Bengali through input method.
Asked
Active
Viewed 3,356 times
For Bengali you can use avro phonetic.
Method 1
Using ibus as input method, you can try with avro m17n package.It works like charm. You can download from here . While installing you might get packaging warning. Ignore that.
- Download the latest dev file, install it.(Read the instruction in
READMEandInstall.txt) - Install
ibus-m17nfrom software center. - Switch input method to ibus and configure ibus like this. You can also install hindi from here. (I never tried)
- Log out and login. Use ctrl + space to switch input methods. To change keyboard shortcut, use
Generaltab of the shown picture.
Add ibus in start up
Courtesy - https://askubuntu.com/a/135566/35775
- Open startup applications from the power cog
- Add
ibus-daemon
Method 2
Traditionally avro is instructed to setup with scim input method. But it doesn't work well in latest ubuntu version (>= 11.10). A ppa package is available (tutorial here) also or can compile for source.
