I solved one problem only to get a follow-up problem.
I have Win 7 and I tried loading 32-bit Ubuntu 11 on the system. It kept failing. I figured out due to another post here that it was because my 3TB drive was too much for it. After repartitioning the HD my friend and I managed to load it onto the system, but it was buggy when it came to updates, so I tried upgrading to Ubuntu 12 (32 bit), but I was still having the too many bits problem.
Plus now it seems like something is wrong with loading anything. Both Win 7 and Ubuntu are there, but neither will load. I get a mostly blank screen with the words:
**error: no such device: 3a0d062c-5f69-4635-9c79-3814c7d5bbed
grub rescue>**
(with what appears to be a command prompt)
I loaded U12, 64 bit version, in the hopes it would repair the boot issue. Everything appeared to install much more smoothly this time and update nicely, but there was no luck in the boot department. Again, all the data is there, but I'm still getting the black screen when I boot up. I've also tried the repair function in Win 7 with the install disk and no love. I can run from a liveCD, but that's still not getting me Win 7 or an installed version of Ubuntu.
I have confirmed both OS are there. Whatever prompts them to actually start seems to be the missing element.
Thank you in advance.
I've tried the terminal commands mentioned below. I get to the third command and:
ubuntu@ubuntu:~$ sudo mount /dev/sdb3 /mnt ubuntu@ubuntu:~$ sudo    mount ~bind/ dev/mnt/dev mount: mount point dev/mnt/dev does not    exist
ubuntu@ubuntu:~$ sudo mount /dev/sdb3 /mnt mount: /dev/sdb3    already mounted or /mnt busy mount: according to mtab, /dev/sdb3 is    already mounted on /mnt
ubuntu@ubuntu:~$ sudo mount ~bind dev    /mnt/sdb3 Usage: mount -V                 : print version
 ubuntu@ubuntu:~$    sudo mount --bind/proc/mnt/sdb3 mount: unrecognized option    '--bind/proc/mnt/sdb3' Usage: mount -V                 : print    version
 ubuntu@ubuntu:~$    sudo mount --bind/proc /mnt/proc mount: unrecognized option    '--bind/proc' Usage: mount -V                 : print version
Boot from Ubuntu Live CD.
Open the Terminal.
Mount the partition your Ubuntu Installation is on. If you are not sure which it is, launch gparted (included in the Live CD) if not then install it via software centre and find out. It is Usually a EXT4 Partition. Replace the XY with the drive letter, and partition number.ex: sudo mount /dev/sda5 /mnt. Then bind the directories, you need, like so:
sudo mount /dev/sdXY /mnt
sudo mount --bind /dev /mnt/dev
sudo mount --bind /proc /mnt/proc
Now we jump into that using chroot.
sudo chroot /mnt
Now to install, check, and update grub you only need to add the partition letter (usually 'a') to replace X ex: grub-install /dev/sda, grub-install –recheck /dev/sda
grub-install /dev/sdX
grub-install --recheck /dev/sdX
update-grub
Now you can exit you mounted hard disk,
exit
sudo umount /mnt/dev
sudo umount /mnt/proc
sudo umount /mnt
Now restart and in terminal
sudo update-grub
Source >> How to Repair/Restore/Reinstall Grub 2 with a Ubuntu Live CD
atenz
  • 12,858
