I want to get a IntelĀ® Wi-Fi 6 AX210 adapter running under ubuntu 18.04. This intel page says that its only supported after kernel version 5.10 but like I understood from here, Ubuntu 18.04 is shipped with kernel 5.4 and I could not manage to get a newer kernel version installed.
Is it possible to install kernel 5.10+ on ubuntu 18.04 or is there any other possibility to get the AX210 adapter running?
Maddin
I found the solution. Basically, it is here https://askubuntu.com/a/1320583. However, I cannot compile the git repo. Instead, I use the intel repo, see below.
First, install some necessary package
sudo apt install flex bison
clone the backport repo, compile and install it:
git clone https://github.com/intel/backport-iwlwifi.git
cd backport-iwlwifi
sudo make defconfig-iwlwifi-public
sudo make
sudo make install
The above probably worked in January 2022, but a year later you can have a problem to compile. So you need a little modification to above instruction. After cd backport-iwlwifi go back to the older version of the repository and then open the sources:
git checkout 5b3f6ff8
cd iwlwifi-stack-dev
If you still have problems with compilation then apply this patch: https://www.spinics.net/lists/backports/msg05376.html (just edit manually nano backport-include/linux/mod_devicetable.h and add 4 lines before end):
--- a/backport/backport-include/linux/mod_devicetable.h
+++ b/backport/backport-include/linux/mod_devicetable.h
@@ -29,4 +29,8 @@ struct mhi_device_id {
 #endif
+#if LINUX_VERSION_IS_LESS(4,17,0) +#define DMI_OEM_STRING (DMI_STRING_MAX + 1) +#endif /* < 4.17.0 */
#endif /* __BACKPORT_MOD_DEVICETABLE_H */
Then go back to instruction: configure, compile and install.
Third, download the driver, or you can download your driver from Intel website.
git clone git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git
cd linux-firmware/
sudo cp iwlwifi-* /lib/firmware/
Reboot the machine and it works for me.
Marcin
Victor
I could not find a solution for this but I replaced the WiFi-adapter with a Intel-AX201, which is obviously supported, and it works.
Maddin
There is no way to get the AX210 supported on 18.04 unless the Kernel team backports a 5.10+ kernel to that release, which is not likely given that it has not been backported already. The closest thing to work with would be upgrading to 20.04 and using the HWE stack there that includes the 5.10.x kernels.
Thomas Ward
  • 78,878
On my 18.04.6, I upgraded the kernel to 5.13.19 and copied the driver from Intel website to /lib/firmware. It worked like a charm after that.
For upgrade I followed the instructions here and used mainline to install the specific kernel version:
How to update kernel to specific version
Intel driver downloaded from here (unzip and copy iwlwifi*.ucode file to /lib/firmware):
https://www.intel.com/content/www/us/en/support/articles/000005511/wireless.html
Champ
  • 219
