Everytime I install an app I will get an error. Why? Because of the "deepin-anything-server". Here come what I get when trying to autoremove.
nguyen@X553MA:~$ LANG=C sudo apt autoremove
[sudo] password for nguyen:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 17 not upgraded.
2 not fully installed or removed.
After this operation, 469 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 404624 files and directories currently installed.)
Removing deepin-anything-server (5.0.1-4) ...
userdel: user 'deepin-anything-server' does not exist
Failed on delete user deepin-anything-server
dpkg: error processing package deepin-anything-server (--remove):
 installed deepin-anything-server package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
My Ubuntu 20.04 install have been apt-bricked. Tell me what should I do?
[NOTE Oct 7, 2021: I have closed this question thank to someone suggested another one whose that was the same as mine. Check the notif on top of my question. Thank you, all. Following the answer which have been [assoicated]Can't install and uninstall packages, can't also remove dde, that issue is fixed.]
pphu15
  • 23
