So I installed Deepin Desktop Environment and got an error while installing but continued anyway, I later on decided I will remove it but then it may not be removed, then I started doing other commands such as sudo apt install -f and it showed me this
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
deepin-anything-server
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
2 not fully installed or removed.
After this operation, 469 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 538850 files and directories currently installed.)
Removing deepin-anything-server (5.0.1-4) ...
userdel: user 'deepin-anything-server' does not exist
Failed on delete user deepin-anything-server
dpkg: error processing package deepin-anything-server (--remove):
installed deepin-anything-server package post-removal script subprocess returned error exit status 1
dpkg: too many errors, stopping
Processing was halted because there were too many errors.
I also tried sudo apt autoremove which showed me this
Is there any solution to this? I can't also install Synaptic since it gives me this
The following additional packages will be installed:
libept1.6.0
Suggested packages:
dwww menu deborphan apt-xapian-index
The following NEW packages will be installed:
libept1.6.0 synaptic
0 upgraded, 2 newly installed, 1 to remove and 0 not upgraded.
Need to get 701 kB of archives.
After this operation, 3,194 kB of additional disk space will be used.
Get:1 http://ph.archive.ubuntu.com/ubuntu focal/universe amd64 libept1.6.0 amd64 1.1+nmu3ubuntu3 [79.6 kB]
Get:2 http://ph.archive.ubuntu.com/ubuntu focal/universe amd64 synaptic amd64 0.84.6ubuntu5 [622 kB]
Fetched 701 kB in 2s (294 kB/s)
Other information: OS : Ubuntu Studio
Are there any workaround for this? or solution? Thanks!
Edit:
Result of apt-cache policy deepin-anything-server
Installed: (none)
Candidate: 5.0.1-4
Version table:
5.0.1-4 500
500 http://ppa.launchpad.net/ubuntudde-dev/stable/ubuntu focal/main amd64 Packages
100 /var/lib/dpkg/status
