System: Ubuntu 20.04 on Asus Vivobook 15 (X415 / M415) [no other OS]
Problem: No Wi-Fi device found by NetworkManager:
root@bhagirathi:~# nmcli device wifi list
root@bhagirathi:~# nmcli device wifi rescan
Error: No Wi-Fi device found.
although driver is loaded correctly (see lspci below ) and device is not blocked (see rfkill below). ifconfig and iwconfig does not show any wireless adapter. The device is recognized by the kernel (see lshw -C network below).
[Edit: Solved. The problem was solved just by turning off the laptop by holding power button. See original answer]
Network information
lspci
01:00.0 Network controller [0280]: Intel Corporation Wireless 8265 / 8275 [8086:24fd] (rev 78)
Subsystem: Intel Corporation Wireless 8265 / 8275 [8086:0110]
Kernel driver in use: iwlwifi
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 04f3:0903 Elan Microelectronics Corp. AX88179
Bus 001 Device 006: ID 0408:3046 Quanta Computer, Inc.
Bus 001 Device 005: ID 8087:0a2b Intel Corp.
Bus 001 Device 004: ID 05e3:0608 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 002: ID 0b95:1790 ASIX Electronics Corp. AX88179 Gigabit Ethernet
rfkill list
0: asus-wlan: Wireless LAN
Soft blocked: no
Hard blocked: no
1: asus-bluetooth: Bluetooth
Soft blocked: yes
Hard blocked: no
2: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
- Secureboot disabled
lsmod
iwlmvm 413696 0
mac80211 1024000 1 iwlmvm
libarc4 16384 1 mac80211
iwlwifi 372736 1 iwlmvm
cfg80211 888832 3 iwlmvm,iwlwifi,mac80211
asus_nb_wmi 28672 0
wmi_bmof 16384 0
asus_wmi 36864 2 asus_nb_wmi,mfd_aaeon
sparse_keymap 16384 1 asus_wmi
wmi 32768 3 asus_wmi,wmi_bmof,mfd_aaeon
video 53248 1 asus_wmi
ifconfig
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback <MAC address> brd <MAC address>
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: enx<IF from MAC [IF1]>: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether <MAC 'enx<IF from MAC [IF1]>' [IF1]> brd <MAC address>
inet 192.168.0.107/24 brd 192.168.0.255 scope global dynamic noprefixroute enx<IF from MAC [IF1]>
valid_lft 4102sec preferred_lft 4102sec
inet6 fe80::83c9:fe89:50f0:fc82/64 scope link noprefixroute
iwconfig
lo no wireless extensions.
enx<IF from MAC [IF1]> no wireless extensions.
- NetworkManager State
root@bhagirathi:~# cat /var/lib/NetworkManager/NetworkManager.state
[main]
NetworkingEnabled=true
WirelessEnabled=true
WWANEnabled=true
- NetworkManager config
[[/etc/NetworkManager/conf.d/default-wifi-powersave-on.conf]]
[connection]
wifi.powersave = 2
[[/etc/NetworkManager/NetworkManager.conf]]
[main]
plugins=ifupdown,keyfile
[ifupdown]
managed=false
[device]
wifi.scan-rand-mac-address=no
[[/usr/lib/NetworkManager/conf.d/10-dns-resolved.conf]]
[main]
dns=systemd-resolved
[[/usr/lib/NetworkManager/conf.d/10-globally-managed-devices.conf]]
[keyfile]
unmanaged-devices=*,except:type:wifi,except:type:gsm,except:type:cdma
[[/usr/lib/NetworkManager/conf.d/20-connectivity-ubuntu.conf]]
[connectivity]
uri=http://connectivity-check.ubuntu.com/
[[/usr/lib/NetworkManager/conf.d/no-mac-addr-change.conf]]
[device-mac-addr-change-wifi]
match-device=driver:rtl8723bs,driver:rtl8189es,driver:r8188eu,driver:8188eu,driver:eagle_sdio,driver:wl
- Netplan configuration
[/etc/netplan/01-network-manager-all.yaml]
network:
version: 2
renderer: NetworkManager
dmesg | grep "iwlwifi"
[ 11.050516] iwlwifi 0000:01:00.0: enabling device (0000 -> 0002)
[ 12.131973] iwlwifi 0000:01:00.0: Found debug destination: EXTERNAL_DRAM
[ 12.131983] iwlwifi 0000:01:00.0: Found debug configuration: 0
[ 12.132961] iwlwifi 0000:01:00.0: loaded firmware version 36.77d01142.0 8265-36.ucode op_mode iwlmvm
[ 13.905140] iwlwifi 0000:01:00.0: Detected Intel(R) Dual Band Wireless AC 8265, REV=0x230
lshw -C network
root@bhagirathi:~# lshw -C network
*-network
description: Network controller
product: Wireless 8265 / 8275
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: 78
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:43 memory:fcf00000-fcf01fff
*-network
description: Ethernet interface
physical id: 1
bus info: usb@1:3
logical name: enx<IF from MAC [IF1]>
serial: <MAC address>
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=ax88179_178a driverversion=5.11.0-37-generic duplex=full ip=192.168.0.107 link=yes multicast=yes port=MII speed=100Mbit/s
