I have a Dell Venue with an Intel CPU and Intel HD graphics card. After I suspend my PC and wake it up, the screen remains black. I can listen to the sound when I press, for example, the volume buttons, but I can't do anything.
I've already tried the following, but nothing worked:
  • Switching gdm3 to lightdm.
  • Replacing gnome-screensaver with xscreensaver.
  • Updating the kernel from 5.11 to 5.13.1.
  • Ctrl+F1 or Ctrl+F2/F3
  • Adding:
    nomodeset / nouveau.modeset=0 / nouveau.blacklist=1 /pci=nomsi
    to GRUB_CMDLINE_LINUX.
  • Changing the power button function from the settings.
If I disable the s3state (sleep state) from the BIOS, it works, but the PC doesn't sleep normally and it continues to drain battery.
Info that may be useful:
  • The BIOS is updated.
  • To boot correctly, I set the following string in GRUB_CMDLINE_LINUX_DEFAULT:
    quiet acpi_osi=Linux nomodeset acpi_backlight=vendor splash
    Without nomodeset, Ubuntu doesn't boot. Without the rest, it is impossible to regulate the display luminosity.
  • Hibernating and waking the PC up using a live Ubuntu USB seems to work.
Perti
  • 61
5 Answers5
This solution did it for me. NVIDIA GeForce GTX 970
Disable nvidia-resume and nvidia-suspend services:
systemctl disable nvidia-hibernate.service nvidia-resume.service nvidia-suspend.service
Suspend/resume works again after that.
Artur Meinild
  • 31,035
Harmen
  • 41
I have Ubuntu 22.04 LTS and this same thing happened to me today. I've tried all of the things I found in different forums but nothing work. I decided to restart my laptop again and switch to Windows because I installed it along with it and decided to reboot again. When I was in the BIOS, I choose the "Advance options with Ubuntu" and instead of choosing the recovery mode, I decided to try going for the Linux Generic and when my laptop rebooted again. It showed me recovering my journal and cleaning my inorphaned inodes and after that I was able to see the login screen again after 3hrs of finding ways to fix it. I hope this answer helps!
I've also disabled the suspend option in my gnome tweaks and the same with the settings turning off the automatically suspend in both options whether it is due to inactivity or plugged in. So far, my laptop backlight is fine. I'll update this answer if ever I'll notice any other unusual changes.
UPDATE: After updating and upgrading last night and shutting down my laptop. I opened it again and decided not to try the same procedure that I did before, instead I went ahead to go boot the Ubuntu and it started smoothly without any lags or black screen.
ace
I also have a Dell Venue - to be precise, a 10 Pro 5056 with an Atom Z8550 (Cherry Trail generation). These chipsets have freeze-after-sleep issues with the most recent kernels.
I've tested several kernels, and the stable ones regarding suspend are the 5.4 series. I'd advice installing a 5.4.1xx to have a recent enough and working kernel. Download from the Ubuntu kernel archive at https://kernel.ubuntu.com/~kernel-ppa/mainline/ - one needs 4 files, linux-headers-5.4.1xx-, linux-headers-5.4.1xx-generic, linux-image-5.4.1xx-* and linux-modules-5.4.1xx-. Download and use sudo dpkg -i linux
Also with these chipsets, sound is often an issue. I ended up using a USB-to jack adapter/sound card. Because even when sound was "sort of working", there was stereo issue.
Another issue is setting brightness, which has a huge impact on battery (altering /sys/class/backlight/intel_backlight/brightness). With some kernels, the backlight brightness cannot be changed and the battery lifetime is killed; only gamma can be set using (like xrandr --output "DSI-1" --brightness ).
List of kernels I've tested:
  • 5.4.53 brightness OK suspend OK sound OK not after suspend
  • 5.4.60 brightness OK suspend ?? sound NO
  • 5.4.75 brightness OK suspend ?? sound NO
  • 5.4.100 brightness OK suspend OK sound OK (after a while when suspend)
  • 5.4.105 brightness OK suspend OK sound NO
  • 5.4.128 brightness OK suspend OK sound sometimes
  • 5.4.130 brightness OK suspend OK sound sometimes on 21.04 - boot failure on 21.10
  • 5.4.150 boot failure on 21.10
  • 5.6.15 brightness OK suspend CRASH sound OK
  • 5.8.18 brightness OK suspend CRASH sound OK
  • 5.10.1 brightness NO suspend OK sound OK
  • 5.10.2 boot failure
  • 5.10.3 brightness NO suspend OK sound OK
  • 5.10.4 brightness OK suspend CRASH sound OK
  • 5.10.10 brightness OK suspend CRASH sound ??
  • 5.10.15 brightness OK suspend sound NO
  • 5.10.19 brightness ?? suspend ?? sound ??
  • 5.10.35 brightness OK suspend CRASH sound ??
  • 5.11.20 brightness OK suspend CRASH sound ??
  • 5.12.15 brightness OK suspend CRASH sound ??
  • 5.13.0 brightness OK suspend CRASH sound OK
  • 5.13.1 brightness OK suspend CRASH sound OK
  • 5.13.13 brightness OK suspend CRASH sound ??
  • 5.14 brightness OK suspend CRASH sound ??
Sly
I don't have much to add but I will say this. I chased every rabbit hole I could find w/power settings because my Kubuntu would wake but just have a black screen, never allowing me to log back in forcing me to restart.
It turned out to be my themes were broken. I found an obscure site on how to fix it, but ultimately I end up just resetting my themes back to normal and it fixed it.
ThunderBird
  • 1,963
  • 13
  • 22
  • 31
my environment
user1@ubuntu-desktop1:~$ cat /etc/issue
ubuntu 22.04 LTS \n \l
user1@ubuntu-desktop1:~$ uname -r
5.15.0-30-generic
user1@ubuntu-desktop1:~$ uname -m
x86_64
my solution
user1@ubuntu-desktop1:~$ sudo apt update; sudo apt upgrade
test
user1@ubuntu-desktop1:~$ systemctl suspend
Press any keys in the mouse or keyboard
success start without black screen
