I've tried this and this. Following the second linked post, fprintd-enroll spits out Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
After following the first linked reddit post, there isn't an option in user settings to setup the fingerprint. Same applies to this script. Any ideas how to make this work?
lsusb:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 27c6:5395 Shenzhen Goodix Technology Co.,Ltd. Fingerprint Reader
Bus 001 Device 003: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 002: ID 046d:c08b Logitech, Inc. G502 SE HERO Gaming Mouse
Bus 001 Device 005: ID 0c45:6723 Microdia Integrated_Webcam_HD
Laptop: Dell XPS 15
CPU: i7-9750H
GPU: GTX 1650
RAM: 16GB
SSD: NVMe
shook_one
  • 309
It’s very rare for Shenzhen Goodix to release a Linux driver for their fingerprint readers as the company generally does just enough to ensure its Windows drivers operate. However, because this is being used by a Dell — and because Dell wants their machines to be fully compatible with Ubuntu — there is a driver available!
Here’s how to install it:
  1. Download the libfprint-2-tod1-goodix_0.0.6-0ubuntu1~somerville1_amd64.deb package file using your browser of choice or via the Terminal like:
    wget -O ~/Downloads http://dell.archive.canonical.com/updates/pool/public/libf/libfprint-2-tod1-goodix/libfprint-2-tod1-goodix_0.0.6-0ubuntu1~somerville1_amd64.deb
    Note: Download the 0.0.6 package or something newer. The original 0.0.4 package is garbage and only ever worked when Dell installed Ubuntu before shipping the device.
  2. In Terminal, install the package with dpkg:
    sudo dpkg -i libfprint-2-tod1-goodix_0.0.6-0ubuntu1~somerville1_amd64.deb
  3. Reboot
  4. Register the fingerprint sensor:
    fprintd-enroll
  5. Configure your device
Starting with 21.10, you may not need to do this anymore as Linux kernel 5.12 and newer will support the device out of the box.
matigo
  • 24,752
  • 50
  • 79
Mentioned libfprint-2-tod1-goodix_0.0.6-0ubuntu1~somerville1_amd64.deb doesn't support 27c6:5395
There is some work in progress in libfprint: https://gitlab.freedesktop.org/libfprint/libfprint/-/issues/189 closed, and moved here https://gitlab.freedesktop.org/libfprint/libfprint/-/issues/376
Also there are some examples communicating with this device here: https://github.com/goodix-fp-linux-dev/goodix-fp-dump
But nothing that can be called production quality driver for this device so far. As of 12/16/2022
l0ki
