This is a common problem, i know but when i plug in my headset the sound keeps coming out of the speakers. The pc model is Acer Aspire 5930. When i start the pc with the headset plugged in, the sound comes out right, but when I plug it in after i have turned it on the sound comes out everywhere. System is ubuntu 12.04 64 bit.
I think your sound card is an Intel. if yes try the solution here.
Original Solution
Go to Realtek official site, accept the disclaimer, then download the audio driver for linux/unix. You need to select version 3 for Kernel 3 or later.
Setup necessary tools to compile this driver.
sudo apt-get install build-essential gcc makeExtract the downloaded file, run
sudo ./installfile from a terminal after going to the extracted folder to compile the driver.Read the
Readme.txtfile for more information.
I had a problem with Sound settings in Ubuntu 12.04. It fixed now
Solution 2:
I have just found another solution:
(It worked for me with Only S/PDIF profile, Sound from both headphone and speaker and not being able to switch profile)
Install alsa-hda-dkms using these commands
sudo apt-add-repository ppa:ubuntu-audio-dev/alsa-daily
sudo apt-get update
sudo apt-get install alsa-hda-dkms
Reboot, And See the result!
