On my laptop most function keys work, but Fn+F5 doesn't. It controls fan speed and mode, like performance or effectiveness or turbo. Also Fn+F10 which turns touchpad on and off.
I've installed the latest version of the kernel and updated Ubuntu.
"fn" keys and combinations are implemented by your actual BIOS, and are not controlled by the operating system.
At least for disabling the touchpad, you can do that using a script or just disable tap-to-click.
For example, this is the script I use to disable tap-to-click with a shortcut key:
#!/bin/bash
STATUS=$(gsettings get org.gnome.desktop.peripherals.touchpad tap-to-click)
case $STATUS in
true )
gsettings set org.gnome.desktop.peripherals.touchpad tap-to-click false
gsettings set org.gnome.desktop.peripherals.touchpad click-method 'areas'
# 2021-07-05 Change also click method: area when tap is off
# notify-send "Tap-to-click Off"
false )
gsettings set org.gnome.desktop.peripherals.touchpad tap-to-click true
gsettings set org.gnome.desktop.peripherals.touchpad click-method 'fingers'
# notify-send "Tap-to-click On"
esac
~/bin/toggletouchpad./home/<yourlogin>/bin/toggletouchpad (where <yourlogin> stands for your login name).Remove the comment sign # if you like to see a notification when you change the status.
