Possible Duplicate:
How can I get my graphics card to be recognized in System Info?
I've installed nvidia current (it works mostly) but the details section of the system settings shows that my driver is standard and the version is unknown. I'm getting a lot of errors and compiz has crashed at least twice.
Any help? What other information should I provide?
Just enter
sudo apt-get install mesa-utils
and voila, it shows it as recognized.
I changed my software sources settings to reflect the settings given. To do this I had to change the download from setting on the ubuntu software tab from 'netherlands' to 'Main server'. In addition to this I had to check the pre released updates (precise-proposed) check box on the updates tab. This gave an additional 60 updates but none of these mentioned nvidia. I installed them anyhow and a reboot was requested. After this reboot there are still no proprietary drivers found and the graphics information in the settings still says 'Driver Unknown, Experience Standard'
update:
the problem is mostly solved by performing the steps found on: mygeekopinions.blogspot on how to install nvidia drivers
sudo add-apt-repository ppa:ubuntu-x-swat/x-updates
sudo apt-get update
sudo apt-get install nvidia-current
After a reboot the additional drivers dialog shows the nvidia proprietary drivers. The graphic settings section of the all settings details window however still shows 'Driver unknown, Experience Standard'.
green
  • 14,406
Desmain
I had the same problem, now doing all the updates after I checked all the configuration you showed through the software sources, which I had to find first (was not visible) and I did thanks to this link.
I did all the updates, still graphics unknown. don't know what else to do, I tried everything, NVIDIA has a massive issue here with ubuntu.
if you get the updates someone recommend you end up with a 640x480 resolution, then you have the xorg problem, seems there's no solution to this problem.
