I installed 12.04 today.
It worked on 11.10.
Now if headphones was plugged in on startup, they works, but if I unplug it, speakers don't work.
If headphones wasn't plugged before startup, sound is in speakers and in headphones at the same time.
Laptop is Acer aspire 5930.
Card: HDA Intel
Chip: Nvidia MCP77/78 HDMI
riad@riad-laptop:~$ cat /proc/asound/pcm
00-00: ALC888 Analog : ALC888 Analog : playback 1 : capture 1
00-01: ALC888 Digital : ALC888 Digital : playback 1
00-02: ALC888 Analog : ALC888 Analog : capture 1
00-03: HDMI 0 : HDMI 0 : playback 1
Same problem in 12.10dev
Which additional info should I provide?
Yannick
  • 15
RiaD
  • 1,395
As ALC1200 and ALC888 seem to be very similar (see this German Wiki Entry) you can try my solution for the Intel HDA ALC1200 on my Acer Aspire 5920 G laptop. After upgrading to Ubuntu 12.04 Precise Pangolin from 11.10 my speakers continued to output the sound when plugging in headphones. In 11.10 the speakers were muted automatically when a headphone was plugged in.
I fixed it by adding a line to /etc/modprobe.d/alsa-base.conf :
options snd-hda-intel model=auto probe_mask=1
Now I've got a lot more options/controls when running alsamixer. One is "Auto-Mute Mode". Set this to "Enabled" if it does not work out of the box.
stehpan
user64643
  • 46
Have paid attention for the same problem few minutes ago on my Acer 5920 (Intel HDA ALC1200), and hda-jack-retask utility that I've found here seems to have solved my problem. There are some comments about working ALC888 too.
Ivan Klass
  • 1,241
