I have a secondary storage drive on my computer mounted at /media/user_name/Data. I get this error when trying to create a new directory:
user_name@cpu:/media/user_name/Data mkdir test
mkdir: cannot create directory ‘test’: Read-only file system
df -h shows it mount at:
/dev/sdc2       466G   77G  390G  17% /media/user_name/Data
I follow instructions from here to remount it as read/write
sudo mount -o remount,uid=1000,gid=1000,rw /dev/sdc2
I try to make a directory again:
cd /media/user_name/Data/
mkdir test
mkdir: cannot create directory ‘test’: No such file or directory
I tried solving it with this solution but the same error exists.
The weird thing is I was able to write to this drive last week. I haven't done anything except boot into windows (on a third drive) and access and write data to the Data drive. I primarily use this drive for storage and to pass files between Windows and Ubuntu.
Checking disks, this is the info for it
Size 500 GB — 418 GB free (16.3% full)
Device /dev/sdc2
UUID 20B666B0B66685DE
Partition Type
Contents NTFS — Mounted at /media/user_name/Data
theastronomist
  • 131
yes i know the answer the reason behind this is that your PC is not completely shut down you have to off the fast shut down options
step 1 Go to power setting
step 2 Go to additional power settings
step 3 uncheck the fast shut down option
for the further details see this video
can not write on secondary disk
tinlyx
  • 3,328
hassan
