-1
I have never installed a Linux distribution before, and want to install Ubuntu 20.04 if possible alongside my fresh install of Windows 7 (update problems) on my HP ENVY 6 notebook.
Ubuntu install started and all works until "Installation type - window" first says:
Your installation medium is on /dev/sdc1. You will not be able to create, delete or resize partitions on this disk, but you may be able to install to existing partitions there.
Then I see a partition table: /dev/sdc ... (my USB drive only), and "device for bootloader installation": /dev/sda.
When I leave and start GParted within Ubuntu Live, an error message pops up saying
invalid argument during seek for read on /dev/sdc (retry/cancel/ignore)
but after that shows me all partitions on the computer.
gparted:
- /dev/sda1 ntfs system (flags boot)
- /dev/sda2 ntfs os
- unallocated
- /dev/sda3 fat32 hp_tools (flags lba)
- unallocated 3.34MiB
  • /dev/sdb1 4 GiB (flags irst)
  • unallocated 26 GiB
I also tried with boot manager
  • from EFI file option1: USB (ACPI...), option2: hp_tools (ACPI...)
  • USB drive with UEFI
  • USB drive
Also Ubuntu 16.04 can't see my SSD partitions when installing alongside Windows 10 did not resolve the problem.
Output Ubuntu Live terminal:
$ sudo parted /dev/sda unit s print
Model: ATA Hitachi HTS54323 (scsi)
Disk /dev/sda: 625142448s
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags 1 2048s 409599s 407552s primary ntfs boot 2 409600s 215326719s 214917120s primary ntfs 3 624928768s 625135615s 206848s primary fat32 lba
Windows 7:
  • Windows BIOS mode is legacy
  • Hibernation (disabled)
  • MBR partition type
Disk 0 (basic):
  • System (ntfs)
  • OS C: (ntfs)
  • Unallocated (~200GB)
  • HP Tools (fat32)
Disk 1 (basic):
  • ... healthy (hibernation partition)
BIOS settings:
  • BIOS InsydeH20 Rev.3.7 F.16, 10 17 2021
  • Hardware VT (disabled)
  • Intel rapid start technology (disabled)
  • Legacy support (enabled)
  • Secure boot (grayed out/can't alter, but says disabled)
  • Boot order is: USB, then Hard Drive, then the rest
Options in BIOS are limited.
Greenonline
  • 2,182
It looks like your SSD is using msdos partition table, which means you need to boot the live USB in BIOS/Legacy mode and install it that way. If you want to use UEFI, you may need to use GPT partition table. There are tools that might allow you to convert msdos to GPT such as this one https://superuser.com/questions/1250895/converting-between-gpt-and-mbr-hard-drive-without-losing-data However, create a backup first as you may lose your data.
