I'm following this recipe to build xf86-input-libinput from source with a patch applied.
The command ./configure --prefix=/usr gives me an error that I haven't been able to resolve:
checking for xorg-server >= 1.10 xproto inputproto >= 2.2... no
configure: error: Package requirements (xorg-server >= 1.10 xproto inputproto >= 2.2) were not met:
No package 'xorg-server' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you installed software in a non-standard prefix.
Alternatively, you may set the environment variables XORG_CFLAGS and XORG_LIBS to avoid the need to call pkg-config. See the pkg-config man page for more details.
I've already installed xserver-xorg, it's at the newest version 1:7.7+22ubuntu1. What am I doing wrong?
Probably doing a similar thing. (see error message below)
Posting a more complete and immediately useful answer:
checking for XORG... no configure: error: Package requirements (xorg-server >= 1.7 xproto inputproto ) were not met:
No package 'xorg-server' found No package 'xproto' found No package 'inputproto' found
You can install the need dev package like so:
sudo apt-get install xserver-xorg-dev
I also needed xutils-dev package:
sudo apt-get install xutils-dev
Thanks to the comment in the previous answer that you can look up package names
Hss
jorfus
  • 284
You need the development package, not just the runtime binary package:
$ dpkg -S xorg-server.pc
xserver-xorg-dev: /usr/lib/x86_64-linux-gnu/pkgconfig/xorg-server.pc
steeldriver
  • 142,475
