I installed xfce4 on my ubuntu today i removed it and installed Gnome back, but after that i had issues where my setting was not able to open i searched about it and found that gnome-control-center was missing from my computer and i then tried to install it and got this error
$ sudo apt-get install gnome-control-center
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies: gnome-control-center : Depends: gnome-control-center-data (< 1:3.37) but 1:3.38.3-1pop1~1625337172~20.04~bdcf8ad is to be installed Recommends: gnome-online-accounts (>= 3.25.3) but it is not going to be installed Recommends: gnome-control-center-faces but it is not going to be installed E: Unable to correct problems, you have held broken packages.
Any idea how can i fix it ?
Edit: After running the command sudo apt-cache policy gnome-control-center-data gnome-control-center i got this output:
gnome-control-center-data:
  Installed: 1:3.38.3-1pop1~1625337172~20.04~bdcf8ad
  Candidate: 1:3.38.3-1pop1~1625337172~20.04~bdcf8ad
  Version table:
 *** 1:3.38.3-1pop1~1625337172~20.04~bdcf8ad 100
        100 /var/lib/dpkg/status
     1:3.36.5-0ubuntu2 500
        500 http://archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu focal-updates/main i386 Packages
     1:3.36.1-1ubuntu5 500
        500 http://archive.ubuntu.com/ubuntu focal/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu focal/main i386 Packages
gnome-control-center:
  Installed: (none)
  Candidate: 1:3.36.5-0ubuntu2
  Version table:
Thanks To @N0rbert I realised i had gnome-control-center-data installed which was for 1:3.38.3-1pop1~1625337172~20.04~bdcf8ad and i just remove it using sudo apt remove gnome-control-center-data and then just reinstalled it using sudo apt-get install gnome-control-center-data gnome-control-center and everything worked fine
ADMI
  • 41
To install GNOME Control Center you have to specify its version manually by using command below:
sudo apt-get install gnome-control-center gnome-control-center-data=3.36.5-0ubuntu2
to avoid conflict with previously installed 3.38.3-1pop1~1625337172~20.04~bdcf8ad version.
To correctly remove all trails of PopOS!, you have to re-add their PPA and then purge it by
sudo add-apt-repository ppa:system76/pop
sudo apt-get update
sudo apt-get install ppa-purge
sudo ppa-purge ppa:system76/pop
N0rbert
  • 103,263
