16
I'm trying to open System Settings but it won't open in any way.
Using GUI, Settings are trying to load for a moment and then they are gone.
Using Terminal (gnome-control-center), I get:
(gnome-control-center:8823): GLib-ERROR **: 14:44:15.433: ../../../glib/gmem.c:138: failed to allocate 13477064712 bytes
Trap Trace/breakpoint (core dumped)
I tried:
sudo apt-get remove gnome-control-center
sudo apt autoremove
sudo apt-get install gnome-control-center
With multiple reboots, but I had no result.
UPDATE!: Same errors persist BUT, when I type:
sudo gnome-control-center
(instead of just "gnome-control-center") suddenly System Settings appear! Is it a user permissions issue? Any suggestions?
UPDATE#2: After some system updates, sudo gnome-control-center now spawns "Segmentation fault".
pomsky
  • 70,557
Zerthimon
  • 402
  • 14
9 Answers9
14
Finally I found a solution!
The cause of this problem was pop-theme, that I installed once, plus its repository entry, that provided me the broken System settings (gnome-control-center). In order to solve this:
  1. I installed Ubuntu desktop PPA.
    sudo add-apt-repository ppa:ubuntu-desktop/ppa
  2. I removed all System76/pop (and other trush) entries, with update-manager, leaving Ubuntu desktop the only one active. update-manager
  3. Now that I have the proper repository entry added, I re-install gnome-control-center.
    sudo apt install --reinstall gnome-control-center
  4. Enjoy Gnome System settings!
Zerthimon
  • 402
  • 14
I had the same issue. I was able to fix by removing the GNOME extension/theme which caused the issue and then running:
Eliah Kagan
  • 119,640
sudo apt install ppa-purge
For the next step the PPA has to be active.
sudo ppa-purge ppa:system76/pop
This removes packages from this PPA if they are not available from Ubuntu repositories, or reverts to Ubuntu package versions.
Zanna
  • 72,312
nobody
  • 5,792
Hmm... a variant of this:
  • Ubuntu 20.04.1 LTS
  • No Pop!_OS' PPA - present.
  • sudo gnome-control-center # worked, from a terminal/shell,
    but not so without 'sudo', no GLib-ERROR, with no output at all.
  • "Ubuntu software" - also affected, didn't try 'sudo' there though.
  • dconf reset -f /org/gnome/control-center/ didn't appear to help.
  • Neither did the apt --reinstall below.
Remedy:
  • Reboot into "recovery console"
    hit ESC ONCE after the BIOS displays to get to the boot menu)
  • run the "dpkg" option to install / fix packages
    this brought in a gcc1 -thingie, didn't pay attention to exactly what*
  • also run fsck option
  • enable networking
  • drop to root prompt,
    press ENTER one extra time at the extra prompt
  • run:
$ apt-get install -f --reinstall gnome-control-center gnome-control-center-data
$ reboot
Note:
Remedy worked only as it was run in recovery mode.
Hannu
  • 6,605
  • 28
  • 45
What worked for me was resetting all configurations of the control-center with the following command:
This works until I click on "Display" in "System Settings". Then it stops working and I need to run the command again.
This was tested on Ubuntu 20.04.1 LTS (x86_64).
Nmath
  • 12,664
I faced the same issue on 20.04. I clearly remember at the time of Ubuntu installation system settings was working perfectly, but out of nowhere this problem arose. What i did:
  1. Reset the gnome-control-center by sudo dconf reset -f /org/gnome-control-center (but the problem didn’t go away).
  2. Then I tried to access settings through the terminal by typing gnome-control-center, but it said I don’t have this installed.
  3. After installing gnome-control-center by sudo apt install gnome-control-center I rebooted and it fixed my problem.
karel
  • 122,292
  • 133
  • 301
  • 332
m.h.sun
I had the same problem and looking at the question and answers here, I checked gnome-control-center in the terminal and it was not installed. Installing it solved the problem. I have no idea what happened.
moddayjob
  • 111
Gnome-control-center is not able to load if any of key is not found. kindly run below commands.
sudo rm -rfv /home/kali/.config/dconf
sudo apt install gnome-control-center --reinstall
Now check the same.
Mr. Linux
  • 195
If you find yourself coming back here every now and then, you can always make a shell script to make your life easier:
nano ~/Desktop/settings-fix
Ctrl+C this:
echo "You again  !?";
echo "Alright, lemme fix that for you  !";
sudo apt install --reinstall gnome-control-center;
echo "You're good to go ";
echo "More here  https://askubuntu.com/questions/1245159/system-settings-wont-open-on-ubuntu-20-04-lts-after-adding-system76-pop-ppa";
Ctrl+Shift + V it in the text editor
Ctrl+Shift + O to save
Ctrl+Shift + X to close the editor
In your terminal:
chmod 744 ./Desktop/settings-fix
sudo cp ~/Desktop/settings-fix /usr/bin
Now whenever you run to this again, you can simply run from your terminal:
settings-fix
