I have a Jabra Evolve 75 headset that I connect via Bluetooth to my Ubuntu 20.04 machine. Everything works fine in principle except for one little annoyance:
Whenever I turn the headset on, it connects and the Output Device is automatically set accordingly in the Sound Settings. This is the way I want it. However, the Input Device remains like it was set before and I manually have to go in to the settings and also change it to Jabra Evolve 75:
How can I configure the settings so that both Input Device and Output Device automatically switch to Jabra Evolve 75 once I turn the headset on?
UPDATE: The Input Device is also automatically switched when the Configuration setting is changed from High Fidelity Playback (A2DP Sink) to HSP/HFP. So if it is possible to automatically select that as a profile, my problem would also be solved.
