I've just added Google Calendar account in Korganizer and it works fine, but these events don't show up in the Clock widget. Is it possible?
Note: this question is about KDE.
int_ua
  • 8,892
There are some known bugs with Korganizer not displaying recurring calendar events from GCal. There are several workarounds which usually involve running shell scripts with cron in order to sync Google calendars locally.
Nik Reiman
  • 1,216
Try this: ->right click on clock ->Digital clock settings ->Calendar ->Add check to "Show events"
Old thread I know but still...
Once you have added the google account to korganizer and have it all sync'd up you should be able to see your calendars. You then need to do as Nik Reiman said and right click on clock ->Digital clock settings ->Calendar ->Add check to "Show events".
I then found that to actually see the results come up I had to skip back a month and then forward, it then refreshed the events in the widget.
