My wife's machine is running with livepatch enabled. Today, the wireless adapter switched to unclaimed after an update.
I'm using Ubuntu 22.04.2.
I tried sudo lshw -C network and got the following:
*-network UNCLAIMED
description: Network controller
product: RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:01:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress cap_list
configuration: latency=0
resources: ioport:3000(size=256) memory:84000000-8400ffff
*-network
description: Ethernet interface
physical id: 11
bus info: usb@2:4.3
logical name: enx00e04c680bd3
serial: 00:e0:4c:68:0b:d3
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.12.13 duplex=full firmware=rtl8153a-4 v2 02/07/20 ip=192.168.68.113 link=yes multicast=yes port=MII speed=1Gbit/s
sudo dmesg | grep 8821:
[70006.427752] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[70006.428760] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[70006.428775] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[81851.972000] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[81851.973041] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[81851.973121] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[90848.444827] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[90848.445824] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[90848.445835] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[93541.235795] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[93541.236835] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[93541.236902] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[98937.036258] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[98937.037168] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[98937.037183] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
Unfortunately, dkms status was not as helpful:
sudo dkms --status
Error! Unknown option: --status
Usage: /usr/sbin/dkms [action] [options]
[action] = { add | remove | build | install | uninstall | match | autoinstall | mkdriverdisk |
mktarball | ldtarball | mkrpm | mkkmp | mkdeb | mkdsc | mkbmdeb | status }
[options] = [-m module] [-v module-version] [-k kernel-version] [-a arch]
[-d distro] [-c dkms.conf-location] [-q] [--force] [--force-version-override] [--all]
[--templatekernel=kernel] [--directive='cli-directive=cli-value']
[--config=kernel-.config-location] [--archive=tarball-location]
[--kernelsourcedir=source-location] [--no-prepare-kernel] [--no-initrd]
[--binaries-only] [--source-only] [-r release (SuSE)] [--verbose]
[--size] [--spec=specfile] [--media=floppy|iso|tar] [--legacy-postinst=0|1]
[--no-depmod] [-j number] [--version]
