I'm trying to install Docker on Ubuntu 20.04 LTS. I'm using the official docs. I have done it before without problems.
Here's the error after running sudo apt-get update:
Hit:1 http://dl.google.com/linux/chrome/deb stable InRelease
Hit:2 http://packages.microsoft.com/repos/code stable InRelease
Get:3 http://security.ubuntu.com/ubuntu focal-security InRelease [114 kB]
Hit:4 http://ir.archive.ubuntu.com/ubuntu focal InRelease
Hit:5 http://ir.archive.ubuntu.com/ubuntu focal-updates InRelease
Get:6 https://download.docker.com/linux/ubuntu focal InRelease [52.1 kB]
Hit:7 http://ir.archive.ubuntu.com/ubuntu focal-backports InRelease
Err:6 https://download.docker.com/linux/ubuntu focal InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
Reading package lists... Done
W: GPG error: https://download.docker.com/linux/ubuntu focal InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 7EA0A9C3F273FCD8
E: The repository 'https://download.docker.com/linux/ubuntu focal InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
I saw How do I fix the GPG error "NO_PUBKEY"? but I couldn't solve the problem.
muru
  • 207,228
5 Answers5
You may want to double-check that the second step in Docker's documentation has been applied against your system:
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo gpg --dearmor -o /usr/share/keyrings/docker-archive-keyring.gpg
Without this, you will not be able to connect to the repo. I've just tested the installation steps on a fresh Ubuntu installation and everything has worked without any problem. Hopefully this is all you need to do
matigo
  • 24,752
  • 50
  • 79
For me I needed to change permissions twice:
sudo chmod 755 /etc/apt/keyrings
sudo chmod a+r /etc/apt/keyrings/docker.gpg
My default umask was preventing apt from even reading in the folder... hope this helps someone.
ifiht
  • 186
There is need for additional step if solution doesn't work. Make sure that the docker entry in sources list has the location of the downloaded key :
deb [arch=amd64 signed-by=/usr/share/keyrings/docker-archive-keyring.gpg] https://download.docker.com/linux/ubuntu jammy stable
twarog1985
  • 51
Just using
didn't solve my problem.
I need further:
sudo chmod a+r /usr/share/keyrings/docker-archive-keyring.gpg
and then sudo apt-get update works well.
Inspired by https://stackoverflow.com/a/68764068/7701908.
one
  • 141
For me:
sudo ln -sf /usr/share/keyrings/docker-archive-keyring.gpg /etc/apt/keyrings/docker.gpg
diennv
