Please, keep in mind that I've just recently started using Linux - Ubuntu as my OS, so if you need anything else related to information of PC/System etc..., please ask me and I will update the question with required info. Thanks in advance!
Problem:
This is one of the scenarios that happens to me and it's pretty much common:
If I open browser (no matter if it's Mozilla or any other browser), but I am currently using Brave browser, and I go on youtube and watch video / play music. After some time, my laptop which is running Ubuntu 20.04 - (I'll post more detailed info on system later on in this post) - randomly freezes and starts playing sound from that youtube video in a loop (So, I hear the sound from the video on youtube that was playing, to be more precise, the last 2/3 of a second of that video).
So when that happens laptop becomes completely unresponsive to any key komands and also mouse freezes. After that happen I have to shut down everything with the Power Off button located on my laptop.
Question: Does anyone know how to solve this problem or why's this happening and is there a way of fixing this?
id:
str1ng
description: Notebook
product: HP Pavilion dv8 Notebook PC (VL131EA#UUZ)
vendor: Hewlett-Packard
version: 039D200000241220001020000
serial: CNF94387ZG
width: 64 bits
capabilities: smbios-2.6 dmi-2.6 smp vsyscall32
configuration:
boot = normal
chassis = notebook
family = 103C_5335KV
sku = VL131EA#UUZ
uuid = 434E4639-3433-3837-5A47-00269E7F1C54
id:
core
description: Motherboard
product: 7001
physical id:
version: 35.35
serial: CNF94387ZG
slot: Base Board Chassis Location
id:
firmware
description: BIOS
physical id:
version: F.25
date: 05/31/2010
capacity: 1536KiB
capabilities: pci upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb biosbootspecification
id:
memory
description: System Memory
physical id:
16
slot: System board or motherboard
id:
bank:0
description: SODIMM DDR3 Synchronous 1067 MHz (0,9 ns)
product: DON'T WANNA GIVE INFO
vendor: Samsung
physical id:
serial: DON'T WANNA GIVE INFO
slot: Bottom - Slot 1
width: 64 bits
clock: 1067MHz (0.9ns)
id:
bank:1
physical id:
serial: 6525C446
slot: Bottom - Slot 2
width: 64 bits
id:
cpu
description: CPU
product: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
vendor: Intel Corp.
physical id:
1f
bus info:
cpu@0
version: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
slot: CPU
capacity: 1734MHz
width: 64 bits
clock: 1066MHz
capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp x86-64 constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni dtes64 monitor ds_cpl vmx smx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 popcnt lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid dtherm ida flush_l1d cpufreq
configuration:
cores = 4
enabledcores = 4
threads = 8
id:
display
description: VGA compatible controller
product: GT216M [GeForce GT 230M]
vendor: NVIDIA Corporation
physical id:
bus info:
pci@0000:01:00.0
version: a2
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration:
driver = nvidia
latency = 0
resources:
irq : 38
memory : d2000000-d2ffffff
memory : c0000000-cfffffff
memory : d0000000-d1ffffff
ioport : 6000(size=128)
memory : c0000-dffff
id:
disk
description: ATA Disk
physical id:
0.0.0
bus info:
scsi@0:0.0.0
logical name:
/dev/sda
version: 0003
capabilities: partitioned partitioned:dos
configuration:
ansiversion = 5
logicalsectorsize = 512
sectorsize = 4096
signature = ac4c8fed
Here's the command that one of users requested
~$ free -h
total used free shared buff/cache available
Mem: 5,8Gi 2,3Gi 428Mi 236Mi 3,1Gi 3,0Gi
Swap: 2,0Gi 0,0Ki 2,0Gi
str1ng@str1ng:~$ swapon -s
Filename Type Size Used Priority
/swapfile file 2097148 780 -2
