19
I purchased a new acer i7-1165G7 @ 2.80GHz × 8 laptop installed ubuntu 20.04 along with dual boot Windows. Whenever I start the laptop either in windows or ubuntu both are making very loud noise. I suspected fan was faulty so I gave it to replace it. Now the laptop came with replaced fan still it is creating too loud unbeareable noise. When I see the processes via top more than 100% cpu consumption is going on for tracker-miner-f and tracker-extract for at least more than half an hour. Please let me know what should I do get rid of this noise? You can see the screenshots of top command here.
Even if you disable all the Search functions in settings, the tracker stuff still runs. I don't have any use for it so I have found the following two commands seem to disable everything for me. I have not noticed any issues by doing this:
tracker reset --hard
systemctl --user mask tracker-{miner-apps,miner-fs,store}
codlord
  • 3,153
Make tracker-miner-fs, tracker-extract,tracker-store non executables. It's a workaround but it works.
sudo chmod -x /usr/libexec/tracker-miner-fs
sudo chmod -x /usr/libexec/tracker-extract
sudo chmod -x /usr/libexec/tracker-store
wasabi
  • 69
Source: https://wiki.ubuntu.com/Tracker
Disabling tracker globally (for all users)
for Ubuntu 22 LTS
  • Edit /etc/xdg/autostart/tracker-miner-fs-3.desktop file with root priviledges
  • Add Hidden=true to the end of the file
for older Ubuntu versions
  • Edit /etc/xdg/autostart/trackerd.desktop file with root privileges
  • Do the same for /etc/xdg/autostart/tracker-applet.desktop if you want
Disabling tracker for current user only
for Ubuntu 22 LTS
  • Not tested (instructions for older Ubuntu versions may work, please comment)
  • Enter the directory ~/.config/autostart, create it if it does not exist
  • Create a file named trackerd.desktop
  • Paste the following into the file, save and exit
[Desktop Entry]
Encoding=UTF-8
Name=Tracker
Hidden=true
igor
  • 781
