I've never encountered this before, but most of the time I was careful to stick a nice ionice -c3 in front of the command to be executed. But this time the use of nice and ionice merely delayed the effect.
Either way, I am using Ubuntu 20.04 as my main system, i.e. as a desktop machine. It's fully patched and up-to-date, running the 5.4 kernel (i.e. none of the other available ones). I am running it with Cinnamon (and yes, it's Ubuntu proper, not Mint or so), but the system had to be installed via a server ISO when I last reinstalled it, because none of the desktop ISOs booted successfully. I'm mentioning this because I am not sure if this plays into it somehow.
When I start 7z to compress a file of dozens of GiB in size, the system becomes entirely unresponsive. No way to switch to the text console, no way to connect via SSH, no mouse cursor movement ...
The only way to recover from this situation is to power-cycle the system (in my case I long-press the power key).
Now I read a bit about the Linux scheduler (I didn't actively tinker with it) after this happened and read that the CFS (Completely Fair Scheduler) is the default scheduler since some versions back. However, clearly it's starving all other processes in favor of a program started with nice ionice -c3 ... doesn't seem even remotely fair.
The systemd journal shows nothing other than indications that the file system driver failed to write for the process hosting a VM, which was concurrently running.
How can I further diagnose this and eventually fix this, so that a system which I intend on using as a desktop won't become totally unresponsive?
NB: I'd rather that the OOM killer steps in and snipes some process than the system becoming totally unresponsive. But as far as I can tell the OOM killer didn't mind.
The system has 64 GiB of RAM, no swap file is active (I can live with the handful of instances where a program fails because I'm out of memory)
# sysctl -A | grep -v _domain | grep '\.sched'
kernel.sched_autogroup_enabled = 1
kernel.sched_cfs_bandwidth_slice_us = 5000
kernel.sched_child_runs_first = 0
kernel.sched_itmt_enabled = 1
kernel.sched_latency_ns = 24000000
kernel.sched_migration_cost_ns = 500000
kernel.sched_min_granularity_ns = 3000000
kernel.sched_nr_migrate = 32
kernel.sched_rr_timeslice_ms = 100
kernel.sched_rt_period_us = 1000000
kernel.sched_rt_runtime_us = 950000
kernel.sched_schedstats = 0
kernel.sched_tunable_scaling = 1
kernel.sched_util_clamp_max = 1024
kernel.sched_util_clamp_min = 1024
kernel.sched_wakeup_granularity_ns = 4000000
... and (UUID redacted) ...
# cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-5.4.0-73-generic root=UUID=xxx ro quiet loglevel=3 vga=current nosplash udev.log_priority=3 rd.systemd.show_status=auto rd.udev.log_priority=3 plymouth.enable=0
(the latter to show that I haven't told it to use a different scheduler)
And the overall configuration is (slightly redacted):
# inxi -b -C -G -m
System: Host: XXX Kernel: 5.4.0-73-generic x86_64 bits: 64 Desktop: Cinnamon 4.4.8
Distro: Ubuntu 20.04.2 LTS (Focal Fossa)
Machine: Type: Desktop System: Dell product: Precision 5820 Tower X-Series v: N/A serial: XXX
Mobo: Dell model: 02M8NY v: A01 serial: /XXX/XXX/ UEFI: Dell v: 2.8.0 date: 01/15/2021
Memory: RAM: total: 62.52 GiB used: 3.56 GiB (5.7%)
Array-1: capacity: 3 TiB note: check slots: 8 EC: None
Device-1: DIMM3 size: 16 GiB speed: 2666 MT/s
Device-2: DIMM7 size: No Module Installed
Device-3: DIMM1 size: 16 GiB speed: 2666 MT/s
Device-4: DIMM5 size: No Module Installed
Device-5: DIMM4 size: 16 GiB speed: 2666 MT/s
Device-6: DIMM8 size: No Module Installed
Device-7: DIMM2 size: 16 GiB speed: 2666 MT/s
Device-8: DIMM6 size: No Module Installed
CPU: Topology: 10-Core model: Intel Core i9-9820X bits: 64 type: MT MCP L2 cache: 16.5 MiB
Speed: 1200 MHz min/max: 1200/4200 MHz Core speeds (MHz): 1: 1200 2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1201
8: 1201 9: 1201 10: 1201 11: 1200 12: 1200 13: 1201 14: 1200 15: 1200 16: 1200 17: 1200 18: 1200 19: 1200 20: 1200
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon Pro WX 7100] driver: amdgpu v: 5.6.20.20.45
Display: server: X.Org 1.20.9 driver: amdgpu unloaded: modesetting
resolution: 1920x1080~60Hz, 1920x1080~60Hz, 1920x1080~60Hz
OpenGL: renderer: AMD Radeon Pro WX 7100 Graphics v: 4.6.14756 Core Profile Context FireGL 20.45
