Ubuntu has ionice, but as far as I can tell, it does absolutely nothing.
I suspect this is because Ubuntu replaced cfq with deadline and deadline doesn't support priorities.
Is there any possible way to have prioritized I/O on Ubuntu anymore?
EDIT: The context is that I have a database restore that easily consumes all my I/O and renders my system unusable until it has finished. I'd like it to remain usable for other tasks.
This answer might be helpfull for Ubuntu 20.04, which lacks the cfq scheduler: https://askubuntu.com/a/1350605
From that answer:
Ubuntu 20.04 is using Kernel 5.4 (with HWE: 5.8) with only the mq-deadline scheduler compiled in.
You can check it by viewing /sys/block/sda/queue/scheduler. The active scheduler has square brackets around. If there are other schedulers compiled in the kernel they are also shown.
Example:
# cat /sys/block/sda/queue/scheduler
[mq-deadline] none
uname -r
5.4.0-26-generic
The mq-deadline scheduler does not support the mechanism used by ionice at the moment, see: https://unix.stackexchange.com/a/160081/27458
Solution: Switch to BFQ scheduler
The bfq scheduler does not need to be compiled in the kernel, it can be loaded afterwards using a kernel module.
Switch to the BFQ scheduler:
# modprobe  "bfq"
# echo "bfq" > /sys/block/sda/queue/scheduler
# echo "bfq" > /etc/modules-load.d/bfq.conf
# echo 'ACTION=="add|change", KERNEL=="sd*[!0-9]|sr*", ATTR{queue/scheduler}="bfq"' > /etc/udev/rules.d/60-scheduler.rules
Check:
mq-deadline [bfq] none
It is probably a good idea to also do a reboot and check again.
BFQ not available on "virtual" kernel
If you are using a "virtual" kernel, you will probably not have the bfq kernel module available because it does not include the linux-modules-extra-5.xxx package.
You can solve this by switching to the "generic-HWE" kernel:
# sudo apt-get install linux-generic-hwe-20.04  linux-tools-generic-hwe-20.04
# reboot
After reboot you should be on kernel 5.8.0-xxx-generic. You can check this:
# uname -r
5.8.0-59-generic
Now you can apply the above solution.
Alternative solution: Systemd scope
If you don't want to switch the IO scheduler, you can use a Systemd scope with a lower IO weight.
Create a file /usr/local/bin/mh_ionice with contents:
#!/bin/bash
if (( EUID == 0 )); then USERMODE=''; else USERMODE='--user'; fi
systemd-run \
  --collect \
  --quiet \
  --scope \
  $USERMODE \
  --nice=19 \
  --property="IOAccounting=yes" \
  --property="IOWeight=1" \
Make it executable:
chmod 755 /usr/local/bin/mh_ionice
Now you can run:
mh_ionice  [heavy_command] [arg] [arg] [arg]
You have to change your scheduler from deadlineto cfq.
You can do that per blockdevice and non permanent via
sudo echo cfq > /sys/block/<blockdevice>/queue
Or for the whole system, permanent via grub, with adding the elevator=cfqparameter to the grub commandline options.
This is an excellent post explaining how you can do that.
What the drawbacks of such a change are is better covered elsewhere.
The TL;DR is
According to the test results, each scheduler has different advantages over others. CFQ scheduler is suitable for the systems that require balanced I/O access and do not need process prioritization. Deadline scheduler has better performance on read-intensive works. Noop is for the systems on the cloud or hypervisors. BFQ performs better on interactive use-case scenarios. Noop is the simplest scheduler and it is considered to have the potential for optimized new implementations targeting SSD block devices.
Robert Riedl
  • 4,401
