69
I have 3 partitions on my computer.
|  Device   |  Type |   Size   |  Used   |                                                 Comments                                                 |
| /dev/sda1 | ntfs  | 104MB    | 35MB    | This is Windows loader        |
| /dev/sda2 | ntfs  | 144598MB | 64536MB | Here I want to install UBUNTU        |
| /dev/sda3 | ntfs  | 105353MB | 20227MB | This my backup partition. I don't want to delete anything from here, I have all my necessary information |
The problem is when I select "Device for boot loader installation" /dev/sda2.
I get:
No root file system is defined.
Please correct this from the partitioning menu.
How can I resolve this?
Zanna
  • 72,312
Emilio
  • 691
The complaining is that you have not defined which will be the "/" (= root partition).
Look at this image and pay attention at the "Mount Point":
desgua
  • 33,215
24
Make sure that the partition file system you wish to install Linux, Ubuntu or Backtrack on it is ext4, ext3 or ext2, and not FAT32 or NTFS.
Then mount / on it:
  1. During the installation process press "change" on the partition you wish to use
  2. Make sure "do not use this partition" scroll is not chosen, scroll to ext4, ext3 or ext2
  3. On the "mount" field write /
  4. Click ok, then next a message will appear saying something like "swap area was not defined, do you wish to continue or choose a swap area?", click "ok" and continue or click "go back" and choose another partition and click change, on the file system scroll choose "swap" and click "ok" and next
This will solve both "no root file system is defined" and the "swap area" message, if you still get the swap area message then on step 4 mount /swap to the partition
Yi Jiang
  • 1,206
Make sure the extension is either:
ext2, ext3 or ext4 but i'd recommend you select ext4-journouling file system. The mount point is in /
v2r
  • 9,707
Zuko
  • 1,277
