Logging in via the shell accessed through Ctrl+Alt-F1 and logging in as guest via the graphical user interface work 0O
When I try to log into my standard user account via the graphical interface, the screen flashes to black for a couple of seconds and bumps me back to a pristine login screen. Entering a wrong password for my user account yields the standard error message - my user account and credential verification seem to be OK.
I suppose that my individual graphics configuration causes problems ... I'm not sure how to reset that. I've tried stopping the UI via
sudo service lightdm stop
executed
sudo nvidia-xconfig
and restarted the UI
sudo service lightdm start
to no avail.
My workstation has a Nvidia GeForce 560-448 graphics card. I've tried getting this fixed with the latest Nvidia 64-bit drivers (cURL'ed from the official website), that is 295.49 and the latest beta driver 302.07.
Anybody have an idea how to get this fixed? Your help is appreciated :)
6 Answers6
I've changed the display manager from the default LightDM to GDM by installing latter via sudo apt-get install gdm. With GDM set as new display manager (execute sudo dpkg-reconfigure gdm if you couldn't set GDM as display manager during installation), I could log in via the old-school graphical login screen it presented me with after a reboot.
Once logged in, I reset my display manager to LightDM by executing sudo dpkg-reconfigure lightdm. After another reboot, things were back to normal: I can log in via the distribution's standard login UI, now.
Check after 12.04 upgrade: can't log in although password is correct. At the bottom of question you'll see:
sudo rm /home/<username>/.Xauthority*
sudo apt-get install --reinstall xorg
sudo reboot
That worked perfectly to me.
angelito
  • 121
This is weird.
I've been running 12.04 for awhile now (a few months) without issue. I haven't logged into the GUI in awhile (I typically shell in or use Webmin). Today, I tried to log into the machine via the GUI with my non-root account, it acts like it's trying to load up the desktop then bounces me back. I'm able to shell into the account without issue.
I created a new account and I can log in via the GUI, but the old account still doesn't work.
I stopped lightdm and started gdm and I was able to gain access into my old account via the GUI.
lightdm is probably choking on something...I've no idea what, since the account home directory of the old account is pretty empty, with the acception of hidden files. I suspect that lightdm is choking on a hidden file.
I was just going to leave it alone and continue to use gdm, but looked at the above possible solution.
Ran sudo rm /home/username/.Xauthority* and didn't reinstall xorg. I stopped gdm and started lightdm. Then I attempted to log into the old account again...with success!
devav2
  • 37,290
sudo useradd -m username1
sudo passwd -m username1
This reset everything back to where I could log in again.
Seth
  • 59,332
Bobby
I had to create a new account username2 thru: sudo useradd -m username2 and set a sudo passwd username2 for it. then I login on it thru lightdm create another account username3 (so it have stuff like sudoers working, what username2 dont have) then I copy all stuff from /home/username to /home/username3 thru "midnight commander" mc then sudo chown username3:username3 /home/username3 -R (it wont chown folders contents that are symlinked, whatchout!) when I login on username3 it seems to be all ok now!
I did several tests, even tried to clean the home path (rename/bkp and use a copy of a newly created home), but I couldnt login on username, so my guess is there is some outside configuration that prevents the username to work but username3 and username2 can login on lightdm. May be at /etc?
I must say also that when the system froze and I forced a hard restart (what made me not be able to login on lightdm), my ctrl+alt+f1 that always gave me a black screen, now is working!! so I wonder what is the configuration file to fix because I believe if I run some standard command I may loose access to my text console ctrl+alt+f1... ?
Check your .xsession-errors file in your home directory for any errors after logging in via Ctrl + Alt + F1.
In my case, I had bad characters in my .profile file from my Git installation (my bad).
After I removed it, I was able to login via the login GUI.
Comment #18 at this question helped me.
Naren
